Thread: car cranks but wont start unless you press accelerator
Results 1 to 8 of 8
  1. #1 car cranks but wont start unless you press accelerator
    utah
    Pretty much the title says it all. I replaced the fuel filter and fuel pump relays and checked for vaccum leaks. The car cranks initially but if i dont give it gas it bogs down. I crank it after it dies down and if i press the accelerator for 3 or 4 seconds it starts up with no problem. there are no problems when it is started up, in fact is runs strong. Any ideas?
  2. #2 Re: car cranks but wont start unless you press accelerator
    SE Level Member Planeboy18's Avatar
    Cleveland Ohio
    Have the same problem with my 2004 GP. From what I can tell it's the MAF. Try unplugging it and cranking the car and it should work. If it does work then your MAF is bad. Hope it helps.
    04 GP GT (1st car now my G-Ma's):
    97 GP GT (GF's): "Project Pink Power"
    00 VW GTI VR6 (15*V6): Slow and Low, That is the Tempo
    91 VW GTI 8v: Big Plans
  3. #3 Re: car cranks but wont start unless you press accelerator
    Oct 2008
    Houston, TX
    I had the same problem on mine but it was the Throttle Postioning Senor on my 98.
  4. #4 Re: car cranks but wont start unless you press accelerator
    Wausau, WI
    Did you check the IAC? Will the car idle once it is started without touching the gas? This is a possible bad IAC...
  5. #5 Re: car cranks but wont start unless you press accelerator
    Des moines,iowa
    yeah i had the same problem on my 88 i changed the mas sensor map sensor and still had it....but after the tps was changed it fixed the problem
  6. #6 Re: car cranks but wont start unless you press accelerator
    Wichita
    If it is the TPS when you shift into reverse you'll hear a loud clank noise.
  7. #7 Re: car cranks but wont start unless you press accelerator
    Oct 2008
    Houston, TX
    I didn't in mine. It would start and then turn off with out touching anything at all. When turning on with accelerator pressed it stay on till I let go and the RPM would fall too low and engine would turn off.
  8. #8 Re: car cranks but wont start unless you press accelerator
    Aug 2008
    KCMO
    this happened on my 98 gtp and it ended up be the fuel pump speed control sensor
  1. 93 with 3.1 wont start!
    By rvdavis in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-02-2009, 05:27 PM
  2. car wont start
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 05:56 PM
  3. cranks wont start
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2009, 08:10 PM
  4. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
  5. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
