Thread: bump stops vogtland
Results 1 to 9 of 9
  1. #1 bump stops vogtland
    Sep 2013
    Massachusetts north shore
    Hey guys I recently bought a set of Kyb and vogtland springs with all new hardware and it was assembled by the previous owner with about less than 3k highway miles on them it looks like it has anti pogo washers and the ride is very rough compared to stock is it required to cut the bump stops I didn't even think to look when installing them but when I checked them with the car on the ground it looks like less than a 1" of travel from what I can see or feel threw the boot so they must need to be cut
  2. #2 Re: bump stops vogtland
    Nov 2014
    BFE,Ohio
    I cut mine I did it before I installed so I'm not sure if needed or not.
    Did my post confuse you? BLAME AUTOCORRECT!
  3. #3 Re: bump stops vogtland
    Sep 2013
    The minute I looked in there with the wheel on I new there was a problem
    How short did you cut it and how soft was the bump stop material to cut
  4. #4 Re: bump stops vogtland
    Oct 2014
    St Augustine FL
    I cut my front bump stops in half with a hack saw when I lowered my car. Its like a high density foam rubber material.
  5. #5 Re: bump stops vogtland
    Sep 2013
    I am wondering what's the easiest way to cut it on the car
  6. #6 Re: bump stops vogtland
    Nov 2012
    Madison
    Are you getting nasty smacks in bigger depressions?
    I haven't had a problem with uncut stops using SSCs and 100,000K FE3s.
    I installed new FE3s and new bellows last week. I didn't bother cutting them.
    I thought about it but the roads aren't all that bad here.
    If you were to undo the mount bolts and raise the car to drop the strut you should be able to wrestle the stop away from the bellows.
    Then use a hacksaw blade(no handle) in between the springs
  7. #7 Re: bump stops vogtland
    Sep 2013
    The roads in Massachusetts are bad real bad but even the small bumps feels like I am driving a Honda with a 2" drop there is no give to it definitely needs a cut
    Honestly I am just to lazy to put it on a lift after working all day to try and see what's gonna be the easiest way to trim it without damaging the shaft
  8. #8 Re: bump stops vogtland
    Nov 2012
    Madison
    Well lowering springs are a bit more no suspension go-kart ride.
    I was somewhat used to it because a compg rides a little more stiff stock.
    Do you have a jack?
    I wish I wouldn't have tossed mine old stuff. I would have mocked a strut up with the old springs and mounts to check it out.
  9. #9 Re: bump stops vogtland
    Oct 2014
    St Augustine FL
    You should be able to cut the stops on the car. I agree with spazz lift the car, pull the boot up and cut the stops using a small blade. A coping saw, hack saw, or even a razor blade would probably work fine. Cutting the stops should give you almost another inch of suspension travel. Leave the larger diameter portion intact and cut the lower small diameter portion. The stops are somewhat progressive in design and the larger diameter will have a higher 'spring rate'. Therefore, if you hit the stops it will be a little harder but you should not bottom out the struts.
  1. Good place to get new dust boots and bump stops for struts?
    By Wotgtp in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2011, 04:04 PM
  2. Eibach's and the bump stops
    By FuglyGTP in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2010, 12:18 PM
  3. cant wait to bump it up
    By BoostJunki3 in forum Off Topic Discussion
    Last Post: 01-24-2010, 06:02 PM
  4. squeaks over every bump
    By twoleos617 in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2009, 10:39 PM
  5. Why does it bump
    By wSquared in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2009, 12:25 AM
