Thread: Turn signals not working
Results 1 to 4 of 4
  1. #1 Turn signals not working
    Apr 2011
    Gainesville, FL
    97 Grand Prix GTP. Neither turn signal is working when I manipulate the lever on the steering wheel. The fuse is not blown. Oddly enough, the hazards work when I press the hazard switch. Wipers also work. Anyone have any ideas? Thanks
  2. #2 Re: Turn signals not working
    St. Louis
    Blinker fluid low
    Other than that, might be the multifunction switch having an issue.
  3. #3 Re: Turn signals not working
    Apr 2011
    Gainesville, FL
    Anyway to determine if multifunction switch, or do I just need to replace?
  4. #4 Re: Turn signals not working
    GT Level Member 0069GTP's Avatar
    Oct 2014
    Western NC
    I have 99 GM service manuals. Could take a look if you still need help.
  1. Has anyone modified combination stop/turn/tail lights to independent turn signals?
    By April Thompson in forum Visual/Body Modifications
    Last Post: 03-02-2015, 08:22 PM
  2. Turn Signals not working?
    By nimo in forum General Tech Discussion
    Last Post: 05-08-2012, 11:54 AM
  3. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  4. turn signals.
    By Koniig in forum Visual/Body Modifications
    Last Post: 11-17-2010, 08:41 AM
  5. Turn Signals
    By brett88 in forum General Tech Discussion
    Last Post: 10-03-2009, 07:21 PM
