Thread: installed new struts/ride height?
Results 1 to 8 of 8
  1. #1 installed new struts/ride height?
    GT Level Member Shiftingshaddow's Avatar
    KC
    yeah. so i put new quick struts on the car all the way around. rock auto. they are the monroe economy struts i believe, not original ride quality.
    well, the car looks like its got a lift kit now. is the height adjustable? or is turning that head on top a no no? i know not to loosen it
    or, will they settle a bit as the weight is on them?
    handles better. feels better than 200K struts and coils.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  2. #2 Re: installed new struts/ride height?
    It won't get any lower, maybe 1/4th in.
    They are always like that, welcome to 4x4 gp.
  3. #3 Re: installed new struts/ride height?
    not adjustable. they may settle a bit, but they are new springs and struts. its gonna sit higher then old worn out crap.
  4. #4 Re: installed new struts/ride height?
    KC
    i expected it to be higher but its really high. my wife saw it and she's like "are those the right parts? It looks funny now."
  5. #5 Re: installed new struts/ride height?
    Apr 2012
    Goderich, Ontario
    I also recently bought 4 Monroe economy struts and all they did was bring the back end level with the front. Front ride height stayed the same.
    -Paul Walker
  6. #6 Re: installed new struts/ride height?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Just threw KYB quick struts on my car about a week and a half ago. Ride height raised about 2 inches on all 4 corners. It seems like they have settled a little. whether thats my eyes getting used to the 4x4 or they actually have, idk. I haven't measured.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  7. #7 Re: installed new struts/ride height?
    Nov 2012
    Madison
    Last week I swapped my SSCS onto new FE3s with new rubber isolators and it raised 1/64 of an inch.
    OK......... maybe a half inch.
    Shouldn't we all know what a comfy Monroe ride is? or does by now.
  8. #8 Re: installed new struts/ride height?
    KC
    They settled noticeably by the next day. The front ones looked really bad at first because i did those first and the back were so worn so it looked like the car was almost doing a wheelie. The fronts are a little higher still. Car rides and handles much better. Cant wait to get it aligned.
  1. How to measure correct ride height?
    By bobc455 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2015, 02:30 AM
  2. stock ride height correct half shaft question
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 06-15-2012, 01:13 AM
  3. performance springs with stock ride height?
    By jdmgtp in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2011, 09:04 AM
  4. Stock Ride Height - 04 GP
    By jmoore4294 in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2011, 07:07 PM
  5. Stock ride height struts/springs
    By Phyrstorm in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2010, 04:11 PM
