Thread: Easy Parking Brake question.
Results 1 to 10 of 10
  1. #1 Easy Parking Brake question.
    Oct 2011
    Toledo, OH
    Can anyone that lives in a place that doesn't have multiple feet of snow show me what part this is? (2004+)
    http://www.tonkinonlineparts.com/p/_.../10055178.html
    My guess is it's just a piece of foam or rubber, not something I care to spend $12 on.
    Parking brake seized up and with all the snow we got, I had no idea I was dragging my ass end until I got on a main road and suspiciously had no power. Bought all 3 new cables and the tensioner/equalizer already. Other then that insulator, I think that's all I'll need.
    7"
  2. #2 Re: Easy Parking Brake question.
    I think that insulator is the rubber piece on the left side of the part that connects the cables and holds them from rubbing on each other. Here's how it all goes together on an 04+ I have 08 knuckles and calipers with new brake cables and I reused the center piece and the rubber insulator thingy.
  3. #3 Re: Easy Parking Brake question.
    Oct 2011
    Toledo, OH
    Thanks Bill. That's got to be it, and looks like it's reusable if it's still on there.
    7"
  4. #4 Re: Easy Parking Brake question.
    FWIW we have a ton of snow and I didn't crawl under for that. I have a ton of pics from when I put the car together.
  5. #5 Re: Easy Parking Brake question.
    the lever on the caliper that your cable hooks to tend to rust up. the cable maybe just fine.
  6. #6 Re: Easy Parking Brake question.
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Jerseydoggs View Post
    Brand new calipers @ end of July. The parking brake cables were pretty chewed up from the incompetent dealer**** not adjusting the super rusty equalizer/tensioner when they changed a caliper so I'm pretty sure water is getting in the sheathe and freezing because the brake won't release when it's cold. If I let it warm up they work fine.
    7"
  7. #7 Re: Easy Parking Brake question.
    GTP Level Member
    Oct 2014
    My motto is never use the parking brake.
  8. #8 Re: Easy Parking Brake question.
    I think I grabbed my equalizer from a JY that looked mint. Then when I put it all together, I put a ton of grease all over the threaded rod, nut and cable ends etc.
  9. #9 Re: Easy Parking Brake question.
    Oct 2011
    Toledo, OH
    Looks like the revised design of the equalizer doesn't use that insulator anyway, which explains why no one carries them.
    http://www.amazon.com/ACDelco-157146...dp/B007Q17AIG/
    7"
  10. #10 Re: Easy Parking Brake question.
    I'd also bet that piece was nothing more than a "it'll never rub in 500,000 miles if we put this here.
  1. Parking brake is now shot.......
    By thegipper in forum General Tech Discussion
    Last Post: 07-12-2012, 08:40 AM
  2. Easy brake upgrade question
    By Elite6 in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2011, 05:35 PM
  3. Parking Brake Issue ?
    By DC1263 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2011, 10:46 AM
  4. parking brake adjustment
    By CMURDAx in forum General Tech Discussion
    Last Post: 12-29-2009, 08:04 AM
  5. parking brake question????
    By vader99 in forum Brakes/Suspension/Chassis
    Last Post: 11-12-2009, 11:48 AM
