Thread: Quick power steering question
Results 1 to 6 of 6
  1. #1 Quick power steering question
    Sep 2011
    Canada
    I need to change the rack in my 2000 GTP. My car's steering specs are "Variable-Effort Power Rack & Pinion". Does this mean I have magnasteer? I don't want to buy the wrong rack! Thanks!
  2. #2 Re: Quick power steering question
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Sounds like it. If you want to be sure pop the hood and look for a wiring harness coming out of the rack close to where the steering shaft connects to the rack. If it has no wiring there it does not have magnasteer. If it has wiring it is magnasteer.
    R.I.P.-----99 black GTX 12.9@107
    97 gp gt turbo--- Hx35, xp cam, 130#, double roller, hv3, l67 block, 42.5#, crap tune by me+ Dhp, devils own injection
    300m, 7/8" 2.93 11.78@118
  3. #3 Re: Quick power steering question
    Most likely.
    Easy check is to just jack up the drivers side of the car and get under it. Look for a wire/pigtail from the back side of the rack.
  4. #4 Re: Quick power steering question
    Sep 2011
    Canada
    Thanks guys. I'll be ordering the rack with magnasteer.
  5. #5 Re: Quick power steering question
    my old rack, see the blue plug on the right side boot, that leads up to the shiftier linkage on the trans where it gets plugged in.
  6. #6 Re: Quick power steering question
    Sep 2011
    Canada
    Thanks Scotty looks like mine!
  1. Power steering question
    By traildog in forum General Tech Discussion
    Last Post: 01-17-2014, 09:37 AM
  2. '98 GTP power steering pump question
    By DrKavorkien in forum Introductions/Noob Questions
    Last Post: 08-31-2012, 10:50 PM
  3. Power steering question
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2011, 03:00 PM
  4. power steering question please help
    By mcsddd in forum General Tech Discussion
    Last Post: 12-05-2010, 10:47 PM
  5. power steering pump question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 10:30 PM
