Thread: ZZP or Intense Coil Overs ?
Results 1 to 7 of 7
  1. #1 ZZP or Intense Coil Overs ?
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    I am going to buy coil overs soon and wondering if one is better than the other and why? I Will be doing this to raise the rear and lower the front for better traction at the track. Ive done the cable mod before but don't feel like dealing with having to cable the rear end up every time I go to the track. Thanks
    Worlds Smallest Dick Award Winner!
  2. #2 Re: ZZP or Intense Coil Overs ?
    intense don't retain the rear sway bar mounting points if you're not able to get mounts put on yourself.
    and ZZP are redistributed from here: http://www.arrautmotorsports.com/parts/w-body
    buy from the source and don't pay the upcharge.
    or make your own coilovers using a set of BC racing coils from another car.
  3. #3 Re: ZZP or Intense Coil Overs ?
    Aug 2013
    McDonald PA
    Not saying your wrong but I'm trying to understand. They are charging 1460 for complete and Zzp is charging 1400 I figured there would be more of a price difference
  4. #4 Re: ZZP or Intense Coil Overs ?
    add in the rear sway bar bracket (+$60).
    so apparently they're the same exact price.
  5. #5 Re: ZZP or Intense Coil Overs ?
    Oct 2012
    Albany, NY
    I don't need the rear sway bar anyway. I'm not looking to build my own , that's why I asked if anyone has experience with intense or ZZP coil overs..
  6. #6 Re: ZZP or Intense Coil Overs ?
    they're going to be very close to the same thing since they'll be stock struts that are shaved to accommodate sleeves being pressed onto them for the spring seats to move up/down on. so....whichever is cheaper since you clearly don't care how the car handles.
    but to also throw another wrench in your plan anytime you change the ride height you completely ruin the alignment so your idea of raising it at the track while you're there, if that's what you meant, will be a bit risky considering the car will be all sorts of wonky after the ride height changes significantly.
  7. #7 Re: ZZP or Intense Coil Overs ?
    Oct 2012
    Albany, NY
    Well I got access to a alignment machine , so I'll just raise the the rear up and put it on the machine b4 I head to the track.
  1. looking for coil overs for my gtp
    By StandAloneCustoms in forum Wanted To Buy - Parts
    Last Post: 08-02-2013, 11:47 PM
  2. lowering springs or coil overs
    By lilmidge12 in forum Introductions/Noob Questions
    Last Post: 02-16-2013, 04:39 PM
  3. QA1 Coil overs?
    By cmal37 in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2012, 08:39 AM
  4. Coil overs ????
    By TNTSS in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2012, 04:13 PM
  5. zzp quick struts or coil overs???
    By mikew99gse in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2011, 08:39 PM
