Thread: Old Thread
Results 1 to 16 of 16
  1. #1 Old Thread
    USA
    Old Thread
  2. #2 Re: 2004 Comp G Sway Bar Bushing Sizes
    Didn't you already make a thread asking this?
  3. #3 Re: 2004 Comp G Sway Bar Bushing Sizes
    Donating User Odi's Avatar
    Chicago South Suburbs
    If still in doubt, lift up the car and look on the current bushings, they should have the size stamped on the side. If not, measure it yourself with calipers. I wanna say the front sway on the compg is 20mm solid, and if I were you, I'd just get a new dorman front sway (34mm solid).
    http://www.gpona.com/forums/04-08-gr...ar-t24573.html
  4. #4 Re: 2004 Comp G Sway Bar Bushing Sizes
    Arizona
    Given that the comp G has better handling then standard 97-03 models id stick with your current comp g setup, no reason to change.
  5. #5 Re: 2004 Comp G Sway Bar Bushing Sizes
    Quote Originally Posted by 91parkave View Post
    Thats the difference between GT's and Comp G's, the better shocks and different swaybars. Not even comparing it to the 97-03 models.
  6. #6 Re: 2004 Comp G Sway Bar Bushing Sizes
    Arizona
    Quote Originally Posted by SpeedGrid View Post
    Exactly I am not changing out the sway bars. I just need new bushings as mine are shot. I can only find the Rear Bushings on but not the fronts.
    The only rear bushings compatible with my car are these that I can find are these.
    http://www.rockauto.com/catalog/more...167&cc=1429691
    Now out of the three Moog bushings I listed which size if good for the front? If they are not compatible at all which bushings do you know of that I can buy for the front FE3 sway bar?
    19.19 is the exact size but 19mm and 20mm will both work for the front, if i were you id get energy suspension bushings they have a grease fitting already installed, plus the polyurethane wont rot like rubber ones do.
  7. #7 Re: 2004 Comp G Sway Bar Bushing Sizes
    this.
  8. #8 Re: 2004 Comp G Sway Bar Bushing Sizes
    Arizona
    PN for 19mm=9.5156
    PN for 20.5=9.5157
  9. #9 Re: 2004 Comp G Sway Bar Bushing Sizes
    Nov 2012
    Madison
    Then like 11/16" / 17.5mm, 9.5155 for the back?
  10. #10 Re: 2004 Comp G Sway Bar Bushing Sizes
    Arizona
    Why would you replace inferior bushings with more inferior bushings
  11. #11 Re: 2004 Comp G Sway Bar Bushing Sizes
    Feb 2013
    37.295091, -121.930053
    cuz he is speedgrid thats why
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  12. #12 Re: 2004 Comp G Sway Bar Bushing Sizes
    Enfield, CT
    Dude get ES
  13. #13 Re: 2004 Comp G Sway Bar Bushing Sizes
    Arizona
    I gave you a es part number BTW
  14. #14 Re: 2004 Comp G Sway Bar Bushing Sizes
    Enfield, CT
    PN for 19mm=9.5156
    PN for 20.5=9.5157
    This is what you really want.
    **** Moog! I had Moog bushings and that **** cracks/splits after awhile.
  15. #15 Re: 2004 Comp G Sway Bar Bushing Sizes
    Everything is OEM.
    It's GM... Energy suspension bushings are baller, they'll outlast anything oem/moog and aren't that much more.
  16. #16 Re: 2004 Comp G Sway Bar Bushing Sizes
    Arizona
    These won't drasticly change your ride quality or anything
  1. Stabilizer Bar Bushing Sizes?
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 01-28-2014, 12:40 PM
  2. sway bar bushing help
    By kking89 in forum General Tech Discussion
    Last Post: 07-29-2013, 04:45 PM
  3. BMR Sway bar bushing PN or supplier?
    By Haney GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 06:22 PM
  4. rear sway bushing?
    By speed demon in forum Brakes/Suspension/Chassis
    Last Post: 08-25-2012, 07:35 PM
  5. 04+ Sway Bar Sizes?
    By aries83 in forum Brakes/Suspension/Chassis
    Last Post: 10-23-2009, 06:48 AM
