Old Thread
Old Thread
Didn't you already make a thread asking this?
If still in doubt, lift up the car and look on the current bushings, they should have the size stamped on the side. If not, measure it yourself with calipers. I wanna say the front sway on the compg is 20mm solid, and if I were you, I'd just get a new dorman front sway (34mm solid).
http://www.gpona.com/forums/04-08-gr...ar-t24573.html
Given that the comp G has better handling then standard 97-03 models id stick with your current comp g setup, no reason to change.
Why would you replace inferior bushings with more inferior bushings
