Thread: Popping sound only while turning left.
Results 1 to 20 of 36
  1. #1 Re: Popping sound only while turning left.
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    the I shaft is connected to the steering gear at one end and to the steering column at the other. Replacing the I-shaft will fix the problem. have someone qualified do this if your not sure as this is the mechanical connection for steering the car. Done wrong and you could cause a crash
  2. #2 Re: Popping sound only while turning left.
    Dec 2012
    Where 4T65E's were born
    Quote Originally Posted by primem View Post
    +1 on what he's saying. I'd make sure there's no play in anything first just in case. But it really sounds like a rack and pinion noise. 04's had a tsb where they pretty much always made that noise by 120k. But any rack can go bad.
    Quote Originally Posted by AceGTP View Post
    I understand now.. From what I see they're about $60-$100 then paying for installation?
    No it would be a lot more than that. It depends on what route you go. Some go to a junk yard and test their luck and do it themselves. If it's fine they get by with around $80. Labor alone is pricey, probably $250 plus the part, which you can get new, reman, or used.
    Sold.
  1. Replies: 1
    Last Post: 08-25-2013, 10:32 AM
  2. Popping/rubbing sound while turning right
    By CapnBreakAlot in forum General Tech Discussion
    Last Post: 04-30-2013, 01:52 PM
  3. popping noise when turning right?
    By tichota126 in forum General W body
    Last Post: 03-24-2013, 04:28 PM
  4. another popping thread....while turning
    By cmashark in forum General Tech Discussion
    Last Post: 04-02-2009, 04:46 PM
  5. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
