Thread: ABS/traction light problem
Results 1 to 6 of 6
  1. #1 ABS/traction light problem
    Sep 2013
    Utah
    Hi All,
    I am new to GPF.net and I am looking for an answer to a problem I've been trying to fix. I have a 2004 Pontiac grand Prix GT1, non supercharged. The problem I am having is that the ABS and traction control light are on and won't go off. I have had it scanned for codes, and the ABS code I am getting is C0121 Valve Relay Circuit Malfunction. I have searched this site, and don't see any posts relating to this code. Can someone please help? I don't really know where to start. There doesn't seem to be a whole lot on the net about this issue.
    Thanks in advance!
  2. #2 Re: ABS/traction light problem
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    hub, check all your wires that go into the hub, one might be disconnected
    2004 Grand Prix GTP 150,000 " The New Edition "
  3. #3 Re: ABS/traction light problem
    Dec 2012
    Where 4T65E's were born
    Check all fuses under the hood to make sure none are blown. The code can mean voltage isn't present at a certain point in the system, a relay in the module I believe.
    Sold.
  4. #4 Re: ABS/traction light problem
    Sep 2013
    Utah
    Thanks to all for posting. I previously checked the fuses and apparently I hadn't checked all of them. There are a total of three fuses under the hood, in the fuse box. The one tittled "ABS SOL", which I assume stands for abs solenoid, was blown. Replaced it and light went off right away. Hope this post helps anyone else that may experience the same issue. Thanks again!
  5. #5 Re: ABS/traction light problem
    Dec 2012
    Yup that's what I was thinking. No problem.
    Sold.
  6. #6 Re: ABS/traction light problem
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I was just going to say your abs sol fuse is blown lol
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. ABS/traction light problem
    By johnfdavids in forum Introductions/Noob Questions
    Last Post: 09-18-2013, 04:32 PM
  2. Traction control light and abs light on
    By Torri040 in forum Brakes/Suspension/Chassis
    Last Post: 09-02-2011, 04:03 PM
  3. ABS Traction Off Light
    By Phrozen99 in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 08:17 PM
  4. ABS and Traction light
    By nanuke in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2009, 01:19 PM
  5. ABS / Traction Light
    By bcrosby51 in forum General Tech Discussion
    Last Post: 12-20-2008, 06:10 PM
