Thread: break job help
Results 1 to 6 of 6
  1. #1 break job help
    GT Level Member reinke's Avatar
    Oct 2008
    cleveland, ohio
    is there anything special i need to know about replacing the brakes on my 01 gt. do the caliper pistons slide or twist back it?
  2. #2 Re: break job help
    Barksdale AFB, LA
    Slide. A smaller c-clamp usually does the trick. I use the old pads as a flat surface to push against.
    2009 Subaru Impreza WRX STI
  3. #3 Re: break job help
    Oct 2008
    cleveland, ohio
    sweet thanks. i gotta get thr front and back done on my lunch break tomorrow. hopefully i can do them in a hour
  4. #4 Re: break job help
    Barksdale AFB, LA
    Just pads will take me 30 minutes for the whole car, including taking the wheels off, putting them on, and torquing bolts to proper specs.
    This is with a chassis lift so all four wheels are just off the ground at the same time.
  5. #5 Re: break job help
    Oct 2008
    cleveland, ohio
    pads and rotors. i know i wont be able to get them all done. i will probably wait until i gethome
  6. #6 Re: break job help
    Barksdale AFB, LA
    Rotors? Not happening. The extra time to take the caliper bracket off will definitely put you over your mark.
  1. What did I break?
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2009, 02:22 AM
  2. Dont ever break into this guys house!!
    By gtpinsc in forum Off Topic Discussion
    Last Post: 09-15-2008, 09:19 PM
  3. ABS and TCS lights are on. Break problems. Plz Help
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-22-2008, 11:58 PM
