Thread: Canuck gxp springs on an 04+ gt.
Results 1 to 8 of 8
  1. #1 Canuck gxp springs on an 04+ gt.
    Jun 2011
    ontario
    Just wondering if there is anything to worry about running the Canuck GXP lowering springs (2.5"/2"). Running, 18" msr wheels +40 offset and don't want to have issues when done but also would like to have it lower than stock.
    Was originally going to go with 1.7" springs but found the gxp springs locally.
    Any thoughts?
    Sent from my SGH-I317M using Tapatalk 2
  2. #2 Re: Canuck gxp springs on an 04+ gt.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Gxp springs locally. Lucky find. Can't get them anymore
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Canuck gxp springs on an 04+ gt.
    SE Level Member Sevex's Avatar
    Aug 2012
    Utah
    I emailed Canuck a few weeks ago and said they still had the GXP springs in stock, I did ask him about putting them on my CompG and he said that the reason they are 2.5'' drop is because of the weight difference of the engine in the GXP vs the GTP. he said if you were to put the GXP springs in the GTP you would be closer to the 1.7'' drop not the 2.5'' thats advertised for the GXP
    04 CompG, 1.9 rr, 90# springs, modded SD headers, 42.5#.... intercooler/3.0 mps coming soon.
  4. #4 Re: Canuck gxp springs on an 04+ gt.
    Jun 2011
    ontario
    Thanks ks... Makes sense.
  5. #5 Re: Canuck gxp springs on an 04+ gt.
    Oct 2011
    MI
    Since when does a vehicle with just a different motor weigh that much more to where it doesn't sit as low. Sounds like some bs answer from a typical customer service line.
  6. #6 Re: Canuck gxp springs on an 04+ gt.
    It makes sense to me. Go fill your trunk with bowling balls and it'll sit lower
  7. #7 Re: Canuck gxp springs on an 04+ gt.
    Arizona
    But the ls4 weighs about the same as the 3800 iron block like 30-40lbs so there logic is completely wrong if anything its cause our bilsteins have a higher shock spring perch than the regular 04+ which is why they engineered an even shorter spring to get us the same drop
  8. #8 Re: Canuck gxp springs on an 04+ gt.
    Aug 2012
    Utah
    the email wasn't very clear on why, but he was sure to tell me that putting the GXP springs on a GTP wont net you the 2.5'' thats listed as the drop. he said it would be closer to the 1.7 that your would see if you just ran the GTP spring
  1. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
  2. SSC springs
    By tod1d in forum Brakes/Suspension/Chassis
    Last Post: 09-06-2011, 06:53 AM
  3. Canuck motorsports
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2009, 12:56 AM
  4. New Canuck
    By Shylok in forum Introductions/Noob Questions
    Last Post: 08-28-2008, 08:53 AM
