Thread: Any reason to replace springs when replacing struts?
Results 1 to 7 of 7
  1. #1 Any reason to replace springs when replacing struts?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    My 2000 GTP has 136k on it, springs don't look like they're sagging, the ass end does sit a bit lower than the front but that's normal from what I've read. I'm going with KYB Excel G struts, would there be any reason to replace the springs also?
  2. #2 Re: Any reason to replace springs when replacing struts?
  3. #3 Re: Any reason to replace springs when replacing struts?
    Sep 2012
    Clarkston, MI
    I figured so. Although my car has been a michigan car it's whole life and the roads here aren't good, plus the previous owner lived on a dirt road. Under every panal and carpet in the interior has dust from the roads.
  4. #4 Re: Any reason to replace springs when replacing struts?
    Yeah springs take a long long long time to show fatigue, they probably will outlast the car
  5. #5 Re: Any reason to replace springs when replacing struts?
    Sep 2012
    Clarkston, MI
    Ok thanks guys.
  6. #6 Re: Any reason to replace springs when replacing struts?
    Dec 2008
    Lawndale, CA
    You could always get some intrigue rear springs to raise it back up.
  7. #7 Re: Any reason to replace springs when replacing struts?
    Ontario
    I had some serious ass saggage. I swapped mine out at like 85K. I don't know why.
  1. Replacing struts??
    By malmar112 in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2016, 01:56 PM
  2. Replacing struts do I need Camber bolts???
    By dhdolphns in forum Brakes/Suspension/Chassis
    Last Post: 09-11-2012, 08:08 AM
  3. 2001 GTP - Replacing Struts - KYB GR2 plus other parts?
    By zguy in forum Brakes/Suspension/Chassis
    Last Post: 03-19-2012, 10:14 PM
  4. When to replace struts?
    By chumley in forum Brakes/Suspension/Chassis
    Last Post: 12-24-2010, 07:31 AM
  5. replacing CPS, can/ should I replace front seal then?
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 08:45 AM
