Thread: What is the widest tire you can fit on stock height, AND lowered 1.4"
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    vogtlands are better springs since they are a fairly commonly used OE company. SSC will go lower, but they're gonna ride more rough.
    you don't really want to hear my opinion about what you should do, though.
    Yea ride qualit is a plus , especially in MN, as the winters destroy our roads.. Most people just order from Vogtlands, or is there a good distributor/vendor on the site here?
  2. #22 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Ontario
    My SSC's ride like BUTTA
  3. #23 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    antioch ill
    but do you got stock struts
  4. #24 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Ontario
    Quote Originally Posted by Matt LE-FAG Palm View Post
    GR-2's which are pretty much...Stock strut replacements. If I were to do it again, I'd go Excel-G which are the new GR-2s, apparently those are a bit better, or balls to the wall, AGX. And that's only if you want to stick with KYB.
  5. #25 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    antioch ill
    i found the springs idk how legit the place is tho
    Auto Part Number 959206 From Vogtland | StreetPerformance.com
  6. #26 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Nov 2012
    MN
    Yea Ive been searching for the Vogtland 959220 ( 04+ ) and nothing seems real reputable so far.. Also Can I still use the stock struts or are they gonna go out pretty quick?
  7. #27 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Arizona
    Exel g's and Zzp lowering springs were really good on my gtp get the whole. Setup for a reasonable price
  8. #28 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Nov 2012
    MN
    Thanks, I see alot of talk about spacers, shoty dog bones LCA bushings etc.. Is all this just a natural problem of lowering, or is this just common on cars that are really slammed down like 2.5-3 inches?
  9. #29 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Arizona
    bigger than a 255 requires wide wheels to compensate for the width of the tires in order to use those tires properly? who do you know that does that? okay then.
    Given that I'm a Gxp owner we can fit 275's on the stock wheel without a wider wheel...
  10. #30 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Quote Originally Posted by 91parkave View Post
    your widest wheel is 8", you're still not making use of the 275 and would probably get more traction with a 255 unless you run really low tire pressures..
  11. #31 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    GTP Level Member joshv's Avatar
    canada
    who the hell would run anything over a 255 on a grand prix unless you really needed the traction? that's just stupid and a waste of money.
    MEEEEE !!!!!!!!!! with 275's and a 35 off set, it rubs with lots of weight in the back, but with finders rolled no rub
    im also lowered on stock struts and the rim is 9 wide
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  12. #32 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Ontario
    Quote Originally Posted by joshv View Post
    Those tires must cost an arm and a leg!!
  13. #33 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    canada
    Quote Originally Posted by Oxfire View Post
    was running goodyear eagle f1's brand new 750 bucks eack ! but i kept buying used ones for 100 bucks fore two from i guy i know.. im now running falkens and there 600 for 2
  1. Stock Ride Height - 04 GP
    By jmoore4294 in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2011, 07:07 PM
  2. Widest rim you can run on a 225/50/18 tire?
    By Bluemagic in forum Tires & Wheels
    Last Post: 02-04-2011, 06:37 PM
  3. Stage "height"
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 04-12-2010, 09:07 PM
  4. Stock crome 16" wheel...what size tire?
    By Boosted02GTP in forum Tires & Wheels
    Last Post: 03-04-2009, 09:57 PM
