Thread: What is the widest tire you can fit on stock height, AND lowered 1.4"
Results 1 to 20 of 33
  1. #1 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    bigger than a 255 requires wide wheels to compensate for the width of the tires in order to use those tires properly? who do you know that does that? okay then.
  2. #2 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Arizona
    Given that I'm a Gxp owner we can fit 275's on the stock wheel without a wider wheel...
  3. #3 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Quote Originally Posted by 91parkave View Post
    your widest wheel is 8", you're still not making use of the 275 and would probably get more traction with a 255 unless you run really low tire pressures..
  1. Stock Ride Height - 04 GP
    By jmoore4294 in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2011, 07:07 PM
  2. Widest rim you can run on a 225/50/18 tire?
    By Bluemagic in forum Tires & Wheels
    Last Post: 02-04-2011, 06:37 PM
  3. Stage "height"
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 04-12-2010, 09:07 PM
  4. Stock crome 16" wheel...what size tire?
    By Boosted02GTP in forum Tires & Wheels
    Last Post: 03-04-2009, 09:57 PM
