You're welcome!
As for the anti pogo washers, you will want a set of FOUR. One for each strut. As for the springs, I sent Will an email about that very thing. I have the Gen II's and from what I read in a previous post of his, the Gen I's sat higher in the rear end. I had asked him about a swap or trade for my Gen II's rears for a set of rear Gen 1's. But I neveer heard back from himI haven't even put them on yet.
I was thinking about going with a new set of stock rear springs myself to give the car a bit more of an agressive forward tilt. NOTHING drastic mind you, but a little lift in the rear and a nice minimal dip in the front gives a nice appearance. That is why I have left my current setup the way it is. SSC's in the front and current stock springs in the rear. But those springs have 85k miles on them and they need replacing sooner than later.
In regards to the Gen II's I mentioned, they are the only ones I have seen for sale. I have not come across any Gen I style SSC springs. So that is why I spoke of them and not the Gen 1's.
I have never seen the Comp G Front sway bar to compare it to the GMPP style of sway bar. But here is a picture I took of my STOCK sway bar as compared to the GMPP sway bar. I think you will see the difference.
As for other Polymounts, I would say go with the Engery Suspension mounts for the sway bar and the sway bar end links. Here is a photo or two of them....
Moog also makes a set similar to the Energy Suspension ones, but I like the red as compared to the dull blue of the Moogs. The one thing I will probably wind up getting from Moog is the read Poly Endlinks from the rear strut to rear sway bar. I have yet to find a real part number for the rear sway bar mounts for Energy Suspension or Moog, but at least Moog has the endlinks, so that also provides more stability when driving.
I hope that helps ya. If you need anything or have anymore questions, do not hesitate to ask![]()
