Woot! Nice to have someone give a detailed reply to this, Thanks!
As far as Pogos, do I need all 4 or just the fronts?
Will at Overkill Motorsports told me he thinks I should go with the original drop from SSC so the assend of my car sits a bit higher, due to my issues with work and such. You said SSCs GenII, why do you say that?
My Sway-bar is .80"/20mm, You think I should get the GMPP bar? Both ZZP & WBS say the Comp-G has the larger bar, so I may have been raped on that one...
I have polys on my dogbones now, and a poly trans mount. What other polys should I be looking at getting?
