I would check the hole position on a 97-03 model compared to the hole position of an 04+. if they have the ame mounting location then I dont see why a 97-03 front suspension wouldnt work on a 04+
the mounting brackets on the subframe have the same brackets as a 97-03. which means you would have to change out the sway bar end links to match the 97-03's.
I am surprised I dont see an afterarket for the 04+.........
The A-arms, spindles, struts, and sway bar end links..... thats off the top of my head. also if the strut mounts on a 97-03 have the same angle as an 04+...... I dont see why they wouldnt.
It is an interesting idea, that would give you pleanty of aftermarket.
anyone elses ideas? I have not done any majo suspension changes on an 04+
