Thread: coilover question
Results 1 to 19 of 19
  1. #1 coilover question
    GTP Level Member
    Sep 2011
    Motown
    Alright I am planning on doing a coilover setup with my new agx struts. I am planning on using this car to autox and things like that. So what I was thinking was putting 500lb springs in the front and putting 400lb springs in the rear. Would this work or is it too strong? I would like it to be pretty stiff. Thanks in advance.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  2. #2 Re: coilover question
    That is too much In my opinion.
    What you will want to go for are springs that are rated for the valving of the struts. I have 400# front and 350# rear, my ride is pretty jarring (stiff doesn't always mean handling). I would imagine the sweet spot for AGX's are around 200-300 area, but I'm not 100% sure.
    Matt has been all about Bilstein's mono tubes and having them valved specifically to a certain setup and I agree with him, its probably the best route. Since you already have the AGX's look into finding out what the sweet spot is spring rate wise.
  3. #3 Re: coilover question
    Google search reveals I was pretty damn close.
    Review: Suspension- KYB AGX Shocks, Racing Beat Springs, Flyin'Miata Swaybars
    Guy seems to think 200# - 250#. I'd run the later of the two in the rear, since a stiffened up rear will help this car rotate around corners; with that 200# up front, I'd stay away from the stiffest Front sway bar, just because these cars are nose heavy and will understeer like a pig; maybe stick to stock or one or two steps up; dialing in your setting on the AGX will be the other part of it. Once you go out a few times on street tires, you will find that limit, leaving you wanting more, so once you reach that point, you will want track tires and wheels and that will make all the difference in the world.
  4. #4 Re: coilover question
    GTP Level Member
    Sep 2011
    Motown
    What shocks are you running? And by chance do you remember the spring lbs for zzps coilovers?
  5. #5 Re: coilover question
    I have the KYB AGX, I'm only running what I am running because of the drop I'm on (around 3.5-4") You will want to find the magic spring rate and only drop 1.5" tops, the more you keep those LCA's parallel with the ground the better. That is why shortening your AGX's rod may not be a bad idea either, since your not after a big drop, then a shortened rod won't hurt you. Other things you can do are when you go for an alignment you want to zero out the toe (I think GPs run 0 toe out) or go 0.5* positive. Going much more then that you will just burn tires (at 0.5* you will burn tires a little faster than normal but its livable) and your turn in will be like night and day.
    As far as ZZP spring rates, I think they run on the light side of things to keep the stock feel to the car, I think 175# and 250# (front/rear respectively). These springs are cheap on Summit, I think $20 a spring, so you may have to try one set of springs for a season, see how it feels and then change to another spring another season, you have to find what is best for you and your driving style. But I'd keep it between 200-300#'s.
    Other things I have considered in the past were Sub Frame Connectors (google it), alot of guys go custom here. I'd tie the front subframe to the rear trailing if I could (I think that would be the best route, but not 100% sure if it would be feasible). These will help stop body flex from corner to corner, which this car has....BAD.
    Other options are Fender braces as well, which when making a sharp turn in, will keep the front pointed straight and where you turn. Since when they make a frame for a car, the passenger cell tends to be seperate from the engine bay compartment, so the firewall can be a weak point. This car doesn't exhibit it as bad as some cars I've had in the past, but it does have some weakness. These two mods can be done down the line once you dial in your suspension and you want to nickel and dime everything.
    Waiting for Matt to chime in....
    There was also talk of aluminum inserts for the subframe bushings at one time, but not sure what happened to that.
  6. #6 Re: coilover question
    Quote Originally Posted by Drunkie View Post
    Ran upwards of 3* of toe out. It made turn in much more lively.
    ZZP is 350/275
    The amount of effort involved in this might not be worth it. Just starting with a better platform would have better results.
    If you're serious, you're going to want something like this:
    Flyin' Miata : Chassis : Stiffening : FM butterfly brace
    Was tempted to get into all of that, but I decided a new subframe and bushings wasn't worth the effort. Same story with the SFC's.
    I found the rear was too weak and flexed under any high speed sweeping corners. Whether that was my stock lateral arm bushings or the rear subframe itself flexing, I couldn't tell you.
    What would probably happen after poly rear link bushings would be the brackets would begin to flex as they're also stamped steel pieces with no bracing. Think of the stock trailing arms.
    After considering all of this, getting out might be the best option.
  7. #7 Re: coilover question
    GTP Level Member
    Sep 2011
    Motown
    How much does your wheel move up and down when your going down a road?
  8. #8 Re: coilover question
    I don't know I never looked.
    Are you asking how much of the strut travel I have left? I figure about 1.5"-2"
  9. #9 Re: coilover question
    Well, alot of people said that about my Maxima, but I stuck with it and pretty soon I was posting better times then Miata's. Really if you want to just have fun then any car will work. If you want to be serious, get a well setup car....*cough cough* Saab. Saab's were known for their chasis's to be so strong that roll cages were just for display purposes only.
  10. #10 Re: coilover question
    More bracing ideas:
    Essentially find things to tie the subframes to.
    Look into converting front LCAs to H body style, or replacing front bushing with spherical bushing. Perhaps ZZP's new LCAs might be worth the risk.
    As I said previously, question the rear subframe as well.
    Jan 2009
    Tallahassee, FL
    Start a new thread on bracing ideas? I'm interested in the topic.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  12. #12 Re: coilover question
    You would need to speak directly with people who have tried various forms of chassis bracing on a W body.
    AFAIK, no one here has that.
    Jan 2009
    Tallahassee, FL
    Y'all seem to know more than me lol
    77 Morris Garage B
  14. #14 Re: coilover question
    Have a gopro?
    Stick it underneath your car and go for a drive.
    See what flexes and go from there.
  15. #15 Re: coilover question
    Unless you can weld yourself, this stuff as a one off is very expensive.
  16. #16 Re: coilover question
    SE Level Member dunnster76's Avatar
    Indiana, PA
    Years ago someone tried making subframe connectors, weld on the pinch weld with bolt on connectors that go across so there was still access to drop the exhaust.
    Didn't sell, or really get produced.
  17. #17 Re: coilover question
    GTP Level Member
    Sep 2011
    Motown
    Ok im getting some braces made up in auto cad right now. And Drunkie, how would you compare your ride with and eibach ride? Stiffer, softer, what? Thanks for the help guys
  18. #18 Re: coilover question
    GTP Level Member
    Sep 2011
    Motown
    Alright I am getting ready to order some coilover parts but need some things cleared up. I was looking at get these sleeves jegs.com
    I measured the agx shock housing and I got around 2.01~ I think it will fit but I am not 100% sure, And I dont really feel like spending $340 on a HT coilover DIY kit. Help would be appreciated.
    Thanks
  19. #19 Re: coilover question
    Jan 2009
    Tallahassee, FL
    Here's some threads of the homemade coilovers. Lots of good information in there and plenty to go by for building them
    ClubGP Message Forum troubleshooting
    77 Morris Garage B
  1. rear coilover pics?
    By Regalgs98 in forum Brakes/Suspension/Chassis
    Last Post: 02-12-2013, 07:57 PM
  2. Custom Coilover Conversion. Looking for Insight Please Help
    By JeremyF89 in forum Brakes/Suspension/Chassis
    Last Post: 12-15-2012, 07:58 PM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
