Thread: Aluminum cradle and firmer bushing swap
Results 1 to 6 of 6
  1. #1 Aluminum cradle and firmer bushing swap
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    Hey everyone. I am currently rebuilding my engine and trans in my 2000 GTP. While everythng is out I would like to install my Aluminum subframe and replace the bushings with something firmer. Like most of you I have looked for poly bushings and came up short. Does anyone have any real world experiance on which GM (or aftermarket) bushings will do the job? I seem to remember reading somthing about buying and installing factory bushings from a 08 GXP with the sport suspension option, but I cant seem to remember. Thanks for the help
    Comp Cams Cam. #150 springs. roller rockers. CNC heads. 3.4" pulley. P&P Gen V. 8-rib w/belt wrap. N* & LQ4. 1" phenolic spacer. P&P/coated LIM. boost temp gauge. Aeromotive fuel rails. underdrive W/P pulley. coated TOG headers. Magnaflow cat back. Random Tech DP & Cat. balance shaft delete. built trans. Hughes converter.
  2. #2 Re: Aluminum cradle and firmer bushing swap
    Honestly if it were me I wouldn't even worry about those bushing. Brand new factory ones will work great. Just make your engine/trans solid mounts or poly and upper dog bones poly if you want a real firm teeth jarring feel.
  3. #3 Re: Aluminum cradle and firmer bushing swap
    Apr 2009
    Peoria, Arizona
    Thanks for the input Fivefinger. Currently I have the Aluminum upper dog bones with poly bushings on both ends. I will be replacing the lower trans and motor mount with either the poly version or new "filled with urethane mod" stock style mounts.
  4. #4 Re: Aluminum cradle and firmer bushing swap
    Comp G bushings should be firmer.
  5. #5 Re: Aluminum cradle and firmer bushing swap
    Arizona
    04+ impala fe4 police package are firmest they should have a green line around them
  6. #6 Re: Aluminum cradle and firmer bushing swap
    Apr 2009
    Peoria, Arizona
    Thank you everyone for your help.
  1. trans swap cradle bolt retainer clip broken
    By 98regal in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-26-2012, 01:29 PM
  2. W-body engine/tranny/cradle swap
    By gtpstyl in forum General Tech Discussion
    Last Post: 09-25-2012, 06:45 AM
  3. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
  4. Installing Cradle (cradle alignment pins)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-16-2008, 05:47 PM
