Thread: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
Results 1 to 20 of 23
  1. #1 What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    I want to keep the car as stock as possible but I hate wheel gap.. SSC and ZZP ( which look almost identical, with the same drop ) are the few I've come across.. Im not racing this, Im not on a road course, but I would like to minimize the wheel gap as much as possible.. I will have about 150 Lbs of audio in the trunk so anything with a 1.5" FR , 1" or less for the rear would be perfect
  2. #2 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    Madison
    I got my SSC's from Canuck Motorsports for 200. They dropped the front and back the same,closer to 2 inches.
  3. #3 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    MN
    Quote Originally Posted by spazzz View Post
    Hows the ride? and is there any alignment/camber issues? I dont want to change a thing on this car, but the wheel gap... and the radio
  4. #4 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    Madison
    my compg was somewhat "stiff" before...nothing to drastic of a ride difference....had an alignment done about 500 miles before the spring swap and honestly didnt even bother with it after,everything appears normal cept the diminished wheel gap
  5. #5 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    MN
    thanks , link?
  6. #6 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    vogtland springs are the least drop and ride pretty close to stock. i won't even bring up DNA springs because they are cheap ebay trash, but i'm sure someone will.
    the next step down, that'll be lower by maybe another half inch to an inch max. those would be SSC, wbody, zzp. all the same spring, really.
    then you go lower with eibach and B&G. the lowest you can go is intrax, but you'll never find those springs for sale anyway.
    ALL of these springs can be run without alignment issues granted that you take your car in for an ALIGNMENT! camber bolts or slotting the struts may be necessary to give a proper alignment, but that's all part of the territory. i have a big thread in this section that is stickied that kind of goes through all of this. have you read it?
  7. #7 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    MN
    The onlu thing I got out of this was your location.. "drunk town USA"
    So, where in Wisconsin are you from
  8. #8 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    Madison
    Quote Originally Posted by comatoast View Post
    now I'm really confused
  9. #9 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    MN
    Sober up.. It will come to ya
  10. #10 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    Madison
    Yeah soooo...SSC's get em
  11. #11 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    "drunk town USA"
    milwaukee. duh.
    but if you didn't follow what i said, you really need to read this thread:http://www.grandprixforums.net/want-...ere-28165.html
  12. #12 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    MN
    milwaukee. duh.
    I read it long ago.. Jst didnt answer the question I asked in my 1st post
  13. #13 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    ^^ I just found them for sale..
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  14. #14 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Ontario
    SSC springs offer a very clean drop and I love how they ride.
  15. #15 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    MN
    Quote Originally Posted by Oxfire View Post
    Like I said in my first post ... zzp and ssc look identical .. same drop and all, But when you bring your car in for an alignment, dont they go off factory specs?
  16. #16 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Kicking around the same thing you are for my 04 GTP. Its kinda down there on the priority list but its there....peekin
  17. #17 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    I guess you havent done alot of suspension swapping??
    Anytime you buy new struts and install lowering springs an alingment is normally needed. There is always a small chance that when you throw everything back together that the camber is almost the same or just more negative. Which in the end just wears the inner edge of the tire more. You could just not care at all and just run it or get an alignment done with camber adjustments if needed and be free of odd wear on the tires.
  18. #18 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    Nov 2012
    MN
    that still wasnt the answer I was looking for.. I know you need alignments after certain ( yet most ) suspension /drivetrain mods or issues... I was just trying to fint out if a certain spring or kit lowered the car without having major issues or weird camber readings
  19. #19 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    ALL lowering springs will affect camber. What do you consider "weird camber readings"?
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  20. #20 Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by Chris BadAss View Post
    x2
    I guess he doesn't get it. You might get away without camber bolts but you need a alignment no matter what after there installed.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Lowering spring ride quality?
    By jerZcavy4120 in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2012, 01:34 PM
  2. Camber after lowering?
    By MyPrixGT06 in forum Brakes/Suspension/Chassis
    Last Post: 03-27-2012, 08:22 AM
  3. Ahh alignment issues. what is wrong here?
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2010, 12:42 PM
