Thread: Who is running the Strut Spring combo from ZZP?
Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
  1. #41
    My upper polys have wear on them and thus squeak from time to time.
    The engine is slowly enlongating the hole.
    Something to keep in mind a little ways down the road.
  2. #42 Re: Who is running the Strut Spring combo from ZZP?
    SE Level Member DanielGTP's Avatar
    May 2012
    United States
    Unfortunately I did not. I fell as though it dropped about an inch in the rear and about an inch and a half in the front.
    How bad of a squeak do they make? Do you notice a huge difference in performance/reliability?
    CAI, 180* T-Stat, AL 104's, SSC Lowering Springs, KYB GR-2's
  3. #43 Re: Who is running the Strut Spring combo from ZZP?
    I've had them on my car for three years.
    I bought them used from someone who had them on their car for a number of years as well.
    So if they last five years, thats pretty good. Your car might not be safe to drive due to rust by then haha.
    The improvement in feel at shifts is worth it.
    They'll only make noise going in and out of the driveway, which is a pretty large bump, at higher speeds than what is comfortable.
  4. #44 Re: Who is running the Strut Spring combo from ZZP?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    See I can live with an inch and half drop up front, but I keep getting mixed reviews about coilover or strut spring combo. I know its only a couple hundred difference but im just trying to be realistic about this car. I mean I dont want to pour money into this thing. And its a daily and I drive a ton........
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  5. #45 Re: Who is running the Strut Spring combo from ZZP?
    coilovers will ride way, way better for the same amount of drop as springs. no questions about it.
  6. #46 Re: Who is running the Strut Spring combo from ZZP?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    By this do you mean comfortable ride quality or performance handling ride quality? Both?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  7. #47 Re: Who is running the Strut Spring combo from ZZP?
  1. amp & sub combo... capacitor?
    By GTPjunkie in forum Audio, Security & Visual Electronics
    Last Post: 03-06-2010, 10:49 AM
  2. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
