get your roters turned. make sure to bleed the system well, check connections to the ss lines. and break in the pads correctly and your problems should go away. and the wobble gets worse with the increase in temp due to the fact that the metal expands.that honestly sounds like your rotors are warped...drive thru a lot of puddles?
