Thread: question
Results 1 to 11 of 11
  1. #1 question
    Jul 2008
    sumter,south carolina
    i have f body brakes...when car is cold it brakes fine but after braking a few times it gets horrible wobble and doenst wanna stop.i had warped rotors before and when they were bad they always wobbled...why only when when the brakes get warm does this happen?
    02 GTP with mods 05 GP for DD
  2. #2 Re: question
    Jul 2008
    Poteau Oklahoma
    could be you need to replace the fluid in your system, #2 you need new lines to the calipers, #3 the pads might be cocked and wearing dionagly(?).
    I am leaning towards #1 with the hard to stop after they warm up, this happened to me once on one of my race cars and drove me nuts trying to figure it out. the brake fluid had exceded the temp adn was old. it just stoped working. my solution was drain all the fluid adn start over.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  3. #3 Re: question
    Jul 2008
    Poteau Oklahoma
    that is assuming you dont have an abs prob>
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  4. #4 Re: question
    Jul 2008
    Quote Originally Posted by justwhisen View Post
    well my abs light is on...i posted a thread about that also and was told it may be bad speed sensor...knowing me i said speed sensor blahhhhhh get to it when i can.i do have brand new ceramic pads i bought the other day...imma put those on tommorow and change fluid out.as for my brake lines they are almost new stainless steel lines...will post new reply after i get pads and fluid swapped out.....and ty for input
  5. #5 Re: question
    Jul 2008
    new ceramic pads and got front rotors turned...abs light is off now and i got TRAC back on
  6. #6 Re: question
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    get your roters turned. make sure to bleed the system well, check connections to the ss lines. and break in the pads correctly and your problems should go away. and the wobble gets worse with the increase in temp due to the fact that the metal expands.that honestly sounds like your rotors are warped...drive thru a lot of puddles?
  7. #7 Re: question
    Jul 2008
    Quote Originally Posted by riceburner View Post
    i fixed it all today...i really didnt think it was rotors.I mean i know metal expands when it gets hot...but when brakes were cold , they didnt wobble AT ALL.Id get down the rd and it would get realllllllly bad to the point of not being able to stop safely.Ceramic pads...got rotors turned and bled brake lines...problem solved.
  8. #8 Re: question
    May 2008
    staten island,NY
    make sure you torque the lugnuts to 100ft lbs. dont use an iron you will warp the rotors again
  9. #9 Re: question
    Jul 2008
    Quote Originally Posted by QwikGT View Post
    i didnt have a torque wrench handy...i used a socket and a wratchet and got them as tight as i could with that.I lost the stock jack and tire iron.
  10. #10 Re: question
    May 2008
    staten island,NY
    get a torque wrench. tight as possible is not 100 ft lbs now you have uneven stress all over the rotor.
  11. #11 Re: question
    Jul 2008
    makes sense my , friend got one at his shop...ill go tommorrow.Thanks man.
  1. 03 GTP Question
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 06:55 AM
  2. IC question
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2008, 09:16 AM
  3. I got a question
    Last Post: 06-11-2008, 05:04 PM
  4. question
    By kingd44 in forum Off Topic Discussion
    Last Post: 02-09-2008, 10:43 PM
  5. question
    Last Post: 02-08-2008, 03:46 AM
