make sure you torque the lugnuts to 100ft lbs. dont use an iron you will warp the rotors again
Originally Posted by QwikGT make sure you torque the lugnuts to 100ft lbs. dont use an iron you will warp the rotors again i didnt have a torque wrench handy...i used a socket and a wratchet and got them as tight as i could with that.I lost the stock jack and tire iron.
get a torque wrench. tight as possible is not 100 ft lbs now you have uneven stress all over the rotor.
Forum Rules
