Thread: Loose Wires
Results 1 to 6 of 6
  1. #1 Loose Wires
    SE Level Member Skoll's Avatar
    Jun 2012
    United States
    So, I wasn't sure if this thread belonged here or in the Tires/Wheels sub forum, but here goes : The other day I was doing a tire rotation on my car with the shops new impact gun, (IR Titanium series),and I noticed this loose wire on my front passenger side.
    I'm still learning about cars and mechanics, so what might come easy to some of you isn't so easy for me, being as inexperienced as I am.
    Any tips or knowledge what this loose wire is or where it goes? Thanks in advance.
    Dec 2010
    DMV
    Looks like the abs wheel sensor? Is your abs light on?
  3. #3 Re: Loose Wires
    St. Louis
    Is it 2 or 1 wire? Could be the wire for the ABS sensor on the hub. Is your ABS light on? Could also be knock sensor, oil pressure switch.
    Worst case take a look at the other side w/ the wheel off and see if you have a matching wire like this one and see what it goes to.
  4. #4 Re: Loose Wires
    Jun 2012
    United States
    Yes, the ABS light has been on since I bought the car, and I never really had the time to properly investigate. It's a 2002 Grand Prix GT if that helps. Series II 3800.
    Dec 2010
    DMV
    Yup. It's a wheel speed sensor. You may get lucky and be able to solder them or just cut and reconnect the wires.
  6. #6 Re: Loose Wires
    Jun 2012
    United States
    Alright, thanks. Guess that will be a project to do tomorrow after I replace the stock radio bulb.
  1. 04+ Loose fog light??
    By gpse2000 in forum General Grand Prix Discussion
    Last Post: 03-26-2012, 08:46 PM
  2. HELP ! can not get my bolt loose HELP !
    By pughman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2011, 08:11 PM
  3. Hubs are loose
    By Clar2478 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2010, 04:03 PM
  4. Loose Fuse?
    By dagger in forum General Tech Discussion
    Last Post: 05-02-2009, 06:08 PM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
