how about rear clunking ? passenger side ? endlinks have a little play, sway bar and strut seems good
check trailing and lateral arms. bet your trailing arms are bent to sh1t.
any pictures ? not too experienced on suspension comp
if it hasn't been said yet the 2 lower bolts need to be pounded out of the strut/knuckle. loosen the bolts, unscrew them to the end so you don't mushroom the end of the bolt, and pound it out.
dont drop it once its loose, watch for the brake lines and such. easy job tho.
reading the repair manual...it says alignment is *mandatory* after strut replacement..i guess i am not doing it tonight as i have a 300mi drive tomorrow;
I was also going to replace rear struts too.. is the alignment necessary again after rear struts?
ok.....sorry for bumping an old thread, but I think it's somewhat related.
Is this lower control arm Mad Monkey mentioned above? it doesn't look good....can I keep it like this?
this is a passenger side.
Thanks!
the shops didn't tell me about the lca when they were doing the struts..and I don't notice any shake on highway. does it mean I can put it off for, maybe, 5k miles?
