Thread: what is this, why is it like this, and what should I do?? [pic]
Results 41 to 60 of 66
  1. #1 Re: what is this, why is it like this, and what should I do?? [pic]
    Donating Users kind153's Avatar
    Pittsburg, KS
    fast!! I'll check that too.. thanks for all the good infos!
  2. #2 Re: what is this, why is it like this, and what should I do?? [pic]
    Donating User Odi's Avatar
    Chicago South Suburbs
    check trailing and lateral arms. bet your trailing arms are bent to sh1t.
  3. #3 Re: what is this, why is it like this, and what should I do?? [pic]
    GTP Level Member
    Oct 2011
    Raleigh, NC
    any pictures ? not too experienced on suspension comp
    1997 Red GTP 182000 miles stock
  4. #4 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    The struts arrive today. I'm going to replace them after work.. anything in particular I should be aware of? any screws that I don't want to unscrew??
  5. #5 Re: what is this, why is it like this, and what should I do?? [pic]
    if it hasn't been said yet the 2 lower bolts need to be pounded out of the strut/knuckle. loosen the bolts, unscrew them to the end so you don't mushroom the end of the bolt, and pound it out.
    dont drop it once its loose, watch for the brake lines and such. easy job tho.
  6. #6 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    I'll keep that in mind. thanks!
  7. #7 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    reading the repair manual...it says alignment is *mandatory* after strut replacement..i guess i am not doing it tonight as i have a 300mi drive tomorrow;
    I was also going to replace rear struts too.. is the alignment necessary again after rear struts?
  8. #8 Re: what is this, why is it like this, and what should I do?? [pic]
    Texas
    Quote Originally Posted by kind153 View Post
    Is it necessary? No. Is it a good idea? Yes.
    85 Corvette
    01 TA
    03 Z06
  9. #9 Re: what is this, why is it like this, and what should I do?? [pic]
    yeah the rear can get out of alignment as well i guess, its all adjustable.
  10. #10 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    It is finally finished! installed two front struts, and 4 wheel alignment.
    Thank you all for your inputs!
    what is this, why is it like this, and what should I do?? [pic] Attached Images
  11. #11 Re: what is this, why is it like this, and what should I do?? [pic]
    London Ont, Canada
    did the noise go away??
  12. #12 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    yup yup
  13. #13 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    ok.....sorry for bumping an old thread, but I think it's somewhat related.
    Is this lower control arm Mad Monkey mentioned above? it doesn't look good....can I keep it like this?
    this is a passenger side.
    Thanks!
  14. #14 Re: what is this, why is it like this, and what should I do?? [pic]
    yeah you can drive on it like that but that pretty worn, make plans to change them both. both sides that is. and then an alignment.
  15. #15 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    do I change the whole arms? or just bushings?
    Ohio
    Change the whole arms. They'll come with new balljoints as well. Ready out of the package for a straight swap.
  17. #17 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    Quote Originally Posted by 99pgpgt View Post
    It will come with new balljoints??
  18. #18 Re: what is this, why is it like this, and what should I do?? [pic]
    yes new arm with new ball joint and new bushings. take the old one out, and slap the new one in, that easy, you'll want an alignment after you are done. your steering wheel may be off a little bit when your done.
  19. #19 Re: what is this, why is it like this, and what should I do?? [pic]
    rock auto has the whole lca for like 40 something a side. yes just replace the whole arm.(s) its like a 3 bolt job really.
  20. #20 Re: what is this, why is it like this, and what should I do?? [pic]
    Pittsburg, KS
    the shops didn't tell me about the lca when they were doing the struts..and I don't notice any shake on highway. does it mean I can put it off for, maybe, 5k miles?
pic
