Thread: Rack and Pinion Help???
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Rack and Pinion Help???
    that must have been one hell of a pot hole to break the damn thing in 2......
    and i told ya it was fun.....
  2. #22 Re: Rack and Pinion Help???
    GT Level Member ill12will8's Avatar
    DC/MD
    yea its was a puddle and pot hole
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
  3. #23 Re: Rack and Pinion Help???
    ah-so the hidden danger. that must have been a shot and a 1/2 lol
    you hit the 4 hour mark on this job?
  4. #24 Re: Rack and Pinion Help???
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Damn that's nuts, esp. if the casting was the only thing to get completely blizted by that.
  5. #25 Re: Rack and Pinion Help???
    DC/MD
    yea more like 5 hours and yea i couldnt believe it when i was pulling it out
  6. #26 Re: Rack and Pinion Help???
    Did you leave the cradle alone or loosen the back 2 bolts ive done both a regal and a gp with the cradle left alone but the swaybar out the hardest part was getting the new one wiggled through all the way. Good see its done!
  7. #27 Re: Rack and Pinion Help???
    sway bars are tricky, aint they, need a twist and a turn and slide, make sure all is clear, then continue.
    i pulled mine out when i did my rack because it was broken. replaced it 3 months later. no sway bar= chit handling car for sure.
    and dropping the cradle makes life easy to remove the sway bar bushing bolts. and a few more inches to give birth to the rack as it come out.
  8. #28 Re: Rack and Pinion Help???
    DC/MD
    i dropped the cradle and took the sway out and give birth is definitely the correct term to use
  1. Looking for a new rack and pinion.
    By QUICKSILVER462 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:43 PM
  2. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
  3. P.S. Rack and pinion? PLEASE HELP!!
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2011, 01:16 PM
  4. rack and pinion
    Last Post: 02-21-2011, 09:53 AM
  5. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
