Thread: What size torx and nuts for control arm
Results 1 to 17 of 17
  1. #1 What size torx and nuts for control arm
    Apr 2011
    Athens, AL
    Anyone know the sizes needed for the two bolts for the control arm on a 01 regal? And what is the torque for them?
  2. #2 Re: What size torx and nuts for control arm
    18mm 21mm and T55 torx. Tighten them to-tight efvckingnuf
    Ohio
    That t55 bolt is the biggest ***** you'll ever encounter
    Sent from my DROIDX using Tapatalk
  4. #4 Re: What size torx and nuts for control arm
    Yoga city
    is that the same for the 97 gp?
  5. #5 Re: What size torx and nuts for control arm
    Should be the same for 97-03 gp and regal.
  6. #6 Re: What size torx and nuts for control arm
    Apr 2011
    Athens, AL
    I know the ball joint nut is a 18 mm. Is the nuts for the main mounting bolts 21mm? And is that T55 torx the correct size for that big torx bolt. I found the actual torque for the mounting nuts. They are 83 ft-lbs. I'm trying to figure out if I have the correct tools to pull one or not. My dad has some big torx but I'm not sure just how big he has.
    Ohio
    Yes t55 is the correct size
  8. #8 Re: What size torx and nuts for control arm
    The one bolt is 18 mm and the nut on the bolt is 21mm. The torx bolt is t55 and the nut is 21mm.
    Ohio
    You sure dan? I'm pretty sure that the bolt head is 19mm and you're right that the nut is 21mm. Heat will be your best friend btw
  10. #10 Re: What size torx and nuts for control arm
    Yeah I did it a couple weeks ago
    Ohio
    Well that's closer to now then when I did it a few months back so you should be right..
  12. #12 Re: What size torx and nuts for control arm
    Scottydogger just did his. Make it look easy. Maybe that's because he was working on his subframe while it was off the car? Either way.. get a big dude and they make it look easy.
    Ohio
    Yeah, those bolts aren't fun whatsoever...
  14. #14 Re: What size torx and nuts for control arm
    Ehhh I've seen them fight and also come out easy. Seems to depend on the car. does your car love you?
    Ohio
    It's a love hate thing
  16. #16 Re: What size torx and nuts for control arm
    Apr 2011
    Athens, AL
    Luckily I am that big guy that people get to break bolts loose lol. Mine aren't necessarily bad but I can see the bushings getting kinda rough looking. Plus the car has 134k on it so the bushings plus the ball joints have got to be either worn out or right on the verge of it. Someone mentioned using heat, which I don't a torch laying around, but I did figure it would probably help to put penetrating oil on them for a few days before I go to break them loose. I'd be pissed if I pulled everything else loose just to find that I could get the mounting bolts off.
    And are the sizes correct as far as everyone knows? I know I've got the 21 mm and I think the big torx. I've got to get an 18mm cause I think I lost it somewhere. Is there enough clearance to put a deep well socket on the nut or do I need a wrench there? It looks like I would have the clearance but I figure someone who has done it would know more than me on the clearance.
  17. #17 Re: What size torx and nuts for control arm
    You'll need a 21mm deep well, 21 mm wrench, 18mm wrench, and a t55 torx bit. I used my impact and that made it go ok. I had to cut my ball joint off because the whole thing was spinning.
  1. LCA removal, What size torx?
    By Boosted02GTP in forum Brakes/Suspension/Chassis
    Last Post: 10-21-2010, 09:01 AM
  2. Torx size for front seats
    By Joe in forum General Tech Discussion
    Last Post: 10-15-2009, 04:21 PM
  3. What size torx for lower control arm screw
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2009, 08:38 PM
  4. Where to find torx studs
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 07:05 PM
