The one bolt is 18 mm and the nut on the bolt is 21mm. The torx bolt is t55 and the nut is 21mm.
You sure dan? I'm pretty sure that the bolt head is 19mm and you're right that the nut is 21mm. Heat will be your best friend btw
Sent from my DROIDX using Tapatalk
