Thread: suspension
Results 1 to 9 of 9
  1. #1 suspension
    Jul 2010
    mobile, alabama
    I have a 2002 gtp, I just replaced both front axles and both front struts including the springs. Why does my car feel like something is bottoming out or rattling when i hit a bump? I checked the tie rod ends and the sway bar everything looks good.
  2. #2 Re: suspension
    Omaha, NE
    Ball joints?
    Strut top mounts?
  3. #3 Re: suspension
    Jun 2011
    Detroit, MI
    Did you replace the strut mounts o install new ones correctly? sounds like the problem.
    iLoveSpade
  4. #4 Re: suspension
    Jan 2009
    Long Island
    Check the same as per ^2
  5. #5 Re: suspension
    i has noise when i cranked my wheel quickly right to left while parked, and while driving over bumps and hard turns. i changed my lca's and its all quiet now. seems as the bushing were all bad, and maybe the ball joints as well.
  6. #6 Re: suspension
    Jul 2010
    mobile, alabama
    i purchased the whole assembly with the springs and all, I didn't think I would need anything else.
  7. #7 Re: suspension
    Minnesota
    Check your sway bar and end links
  8. #8 Re: suspension
    Omaha, NE
    Then it came with the top mounts.
    Start checking for play in things like ball joints, it could even have the feel from motor mounts, etc.
  9. #9 Re: suspension
    Jul 2010
    mobile, alabama
    I was kinda thinking motor mounts,because it only does it over bumps. The car drives great now after the strut and axle replacement. the end links and sway bar doesn't have any play in them.
  1. 04+ suspension
    By Taz Magister in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2011, 11:02 PM
  2. 97-03 GTP suspension
    By GPSE in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2010, 09:46 AM
  3. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
  4. Suspension
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-10-2009, 08:30 AM
  5. Suspension Help
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2008, 08:41 PM
