When my 00GT did this it was the rack. You'll have to check and see if you have a Magnasteer rack or not. If you have a small wire coming up from near where the steering shaft connects to the rack, then you have Magnasteer (variable steering). My pump and lines were fine, although I did replace the pressure line while I had it out seeing as it had almost 200K on it. Cheap insurance against leaks.
