Thread: Turning problems
Results 1 to 7 of 7
  1. #1 Turning problems
    Oct 2011
    Brockton Ma
    My pontiac grand prix gt 1999 wont turn left u have real pull turn it what does it mean how much is it going to cost me to fix it
  2. #2 re: Turing problems
    Likely it's low power steering fluid, a bad power steering pump, or a bad rack and pinion.
    Dunno how much it's going to cost. Depends on how much lube the mechanic applies before he bends you over.
  3. #3 re: Turing problems
    May 2011
    Kansas City
    ^this
    Reptile Tune (SOLD)
  4. #4 Re: Hi I new
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    who needs to turn left, i wouldn't worry about it
  5. #5 Re: Turning problems
    Aug 2008
    Seattle, WA.
    Great answer's for members searching for info,
    Mine won't turn right at all, fluid level is good,
    Thinking rack and pinion.
    What ya think of this item
    on Ebay?
    http://item.mobileweb.ebay.com/viewi...d=330557920938
    1997 Grand Prix SE 3800 series 2
    No mods yet.
  6. #6 Re: Turning problems
    St. Louis
    When my 00GT did this it was the rack. You'll have to check and see if you have a Magnasteer rack or not. If you have a small wire coming up from near where the steering shaft connects to the rack, then you have Magnasteer (variable steering). My pump and lines were fine, although I did replace the pressure line while I had it out seeing as it had almost 200K on it. Cheap insurance against leaks.
  7. #7 Re: Turning problems
    Mine did that when the rack went. It took me about 2 hours to change the first time about 45 min the second time when the rack i put in was bad and i had to swap it out for a new one instead of a junk one from the junkyard.
  1. ABS, TCS problems?
    By astros2900 in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2011, 07:27 PM
  2. problems! help!
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2011, 12:15 AM
  3. D.I.C. problems
    By izup69 in forum 04+ Specifics
    Last Post: 09-04-2010, 11:23 AM
  4. Problems getting hub off
    By chevy man in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2010, 11:26 PM
  5. More problems?!?!?!?!?
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 11-01-2008, 01:09 AM
