Thread: Wheel Alignment and car still pulls badly to the right
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Wheel Alignment and car still pulls badly to the right
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    theres a bearing that the coil sits on, on the strut assembly. they get dirt in it and get worn out. does your car pull ONLY to the right? test this out, at a complete stop. turn the wheel all the way to the left ( probably dosent need to be all the way), then straighten it AS YOU accelerate. after that, if it feels like its not pulling as hard to the right, or is even going straight, the bearing im talking about is bad (not sure of the name)
  2. #22 Re: Wheel Alignment and car still pulls badly to the right
    Donating Users Burgundyman's Avatar
    Quote Originally Posted by jpmiller View Post
    will give this a try. Yes, it pulls only to the right. Does anyone know what this bearing is called?
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  3. #23 Re: Wheel Alignment and car still pulls badly to the right
    i would assume your talking about the strut mount.
  4. #24 Re: Wheel Alignment and car still pulls badly to the right
    Jul 2011
    Michigan
    the part im talking about is called "the spring seat with pivot bearing" in the picture.
  5. #25 Re: Wheel Alignment and car still pulls badly to the right
    Cool. Thanks. Will see if I can get this part to fix the problem.
    RED- 4 Door Sedan
  1. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  2. Wheel Alignment??
    By apierce1289 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2011, 10:09 PM
  3. 2nd gear pulls...
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 12-31-2010, 11:01 PM
  4. Wheel alignment
    By kissmyss in forum General Tech Discussion
    Last Post: 04-19-2010, 12:13 PM
  5. What kind of wheel alignment do I need?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-22-2009, 11:23 PM
