Re: Wheel Alignment and car still pulls badly to the right
theres a bearing that the coil sits on, on the strut assembly. they get dirt in it and get worn out. does your car pull ONLY to the right? test this out, at a complete stop. turn the wheel all the way to the left ( probably dosent need to be all the way), then straighten it AS YOU accelerate. after that, if it feels like its not pulling as hard to the right, or is even going straight, the bearing im talking about is bad (not sure of the name)
jpmiller
will give this a try. Yes, it pulls only to the right. Does anyone know what this bearing is called?
i would assume your talking about the strut mount.
http://i204.photobucket.com/albums/b...390/strut1.jpg
the part im talking about is called "the spring seat with pivot bearing" in the picture.
jpmiller
Cool. Thanks. Will see if I can get this part to fix the problem.
