Thread: Rear end sag?
Results 1 to 14 of 14
  1. #1 Rear end sag?
    Acworth, Georgia
    So I have ebaichs with some blown Gr2s and blown strut mounts. Im getting some agxs and replacing all the strut mounts but didnt know if I should get new springs too. I dont know how many miles are on the springs because I bought it used but my rear is about an inch lower then the front. Will that be fixed with new struts?
  2. #2 Re: Rear end sag?
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    I put new struts on my 96 gp, and it sat level for about a week and then went back to tthe rear saging. from i hear its normal for the rear ends to sag on gp's.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  3. #3 Re: Rear end sag?
    Dec 2008
    Lawndale, CA
    Eibachs are known to have rear sagging issues especially the first generation eibachs.
  4. #4 Re: Rear end sag?
    MA
    the new ones are supposed to sit level though
    SMGPFC Member #9
  5. #5 Re: Rear end sag?
    I just put in monroe quick struts all the way around on my grand prix and it sits nice and level. Been in for a good month and a half now. It used to sag. I used the sensa tracs models not the econo line.
  6. #6 Re: Rear end sag?
    Acworth, Georgia
    Well I know my struts are terrible so hopefully a new set of AGXs will fix it
  7. #7 Re: Rear end sag?
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    Rear end sag = Kim Kardashian
  8. #8 Re: Rear end sag?
    its fairly typical, but if you actually measure the fenders from the center of the hub i bet you they are pretty close. the shape of the fenders is different.
  9. #9 Re: Rear end sag?
    SE Level Member gtx3800's Avatar
    Gillespie, IL
    I fixed this problem on my 99 GTX by getting a piece of steel reinforced rubber belting that was 1" thick and roto-zipped 2 rings out. installed them between the spring and upper mount. And it had Eibachs.. 7 years later, still no sag
    THERE IS NO REPLACEMENT FOR DISPLACEMENT!
  10. #10 Re: Rear end sag?
    Dec 2008
    Lawndale, CA
    I have read about others doubling up on the rear rubber spring isolator to add more height.
  11. #11 Re: Rear end sag?
    Acworth, Georgia
    Quote Originally Posted by The Guz View Post
    I think ill have to try that.
  12. #12 Re: Rear end sag?
    GT Level Member Tea Time's Avatar
    New Brunswick
    gonna revive this one instead of creating a new thread...
    how does one tell if they have 1st gen eibachs? the rear on my gp is sagging hard with eibachs. i was hoping that the springs are tired (if that makes sense) . thats about the only thing it could be...
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  13. #13 Re: Rear end sag?
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    if your rear end is sagging, its your springs. struts will not change ride height.
    2004 comp g
  14. #14 Re: Rear end sag?
    New Brunswick
    ok, i didn't think the eibachs would fail like they did but the car gets parked in the yard during the winter and the snow lays on the car all winter so maybe that didn't help.
    '97 GTP - Project
  1. 4 ohm vs 8 ohm rear 6x9's?
    By mngtp in forum Audio, Security & Visual Electronics
    Last Post: 05-06-2011, 11:53 AM
  2. Rear end Sag
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 05-18-2010, 07:42 PM
  3. rear o2
    Last Post: 04-21-2009, 02:54 PM
  4. Rear O2
    By probuilder1 in forum General Tech Discussion
    Last Post: 07-27-2008, 10:12 PM
