Thread: Shudder/Chatter from rear driving over bumps
Results 1 to 8 of 8
  1. #1 Shudder/Chatter from rear driving over bumps
    GT Level Member Yarbeau's Avatar
    Jun 2010
    Edmonton
    Car is a 2000 GTP. Tires are new.
    Odd feeling whenever I go over a bump or hit a pothole etc. the back right tire seems to almost chatter like its hopping off the road for a second. I know it isn't but that's the feeling I get.
    Any ideas? Im completely lost.
    2000 Daytona 500 - Tog Headers with catted Downpipe, EGR Delete, 180* Thermostat, Solid engine mount, Poly tranny mount/Dogbones, K&N CAI with a custom tune.
  2. #2 Re: Shudder/Chatter from rear driving over bumps
    St. Louis
    Could be shot struts/spring. Did the rear tires wear evenly before they were changed?
  3. #3 Re: Shudder/Chatter from rear driving over bumps
    check the strut towers for rust.
    then theres the sway bar in the rear, if the bushings are shot it can rattle. theres end links for the rear too.
  4. #4 Re: Shudder/Chatter from rear driving over bumps
    GTP Level Member
    Aug 2012
    st louis park, MN
    Have you ever followed a car with a tire that is rapidly bouncing up and down after they hit any sort of imperfection in the roadway? That is a worn shock/strut.
    How many miles do you have on it and when were your shocks last replaced? If you want to test the rear shocks, find a rear body panel that you won't dent with your body weight and rhythmically get the back bouncing up and down. Once you stop, the car should bounce once or a small second time (and maybe a little sideways wiggle after that). If it continues to bounce more than a couple times, your shocks are shot.
  5. #5 Re: Shudder/Chatter from rear driving over bumps
    Jun 2010
    Edmonton
    Tires wore evenly previously. no tower rot at all, they are clean. Shocks bounce once and level out, no pogo effect here.
    Im thinking sway bar personally. that's what its feeling like to me... Just gets a little off track and is then pulled back in, if that makes any sense!
  6. #6 Re: Shudder/Chatter from rear driving over bumps
    Enfield, CT
    worn, defective, or just plain crappy tires can do this too but yea check the rear sway bar, links and bushings. Make sure the trailing arm(s) and lateral links/Track bars aren't bent either. Struts too but I don't they are bent and look at the springs as well
  7. #7 Re: Shudder/Chatter from rear driving over bumps
    Pennsylvania, USA
    If all the suspension parts are tight, check your e-brake assembly. They make an awful noise when the support insulator inevitably rots away. You can rule it out by lightly engaging the e-brake when going over bumps, if the noise changes or goes away then that's it. Mine makes an awful noise because it taps the body of the car going over bumps.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  8. #8 Re: Shudder/Chatter from rear driving over bumps
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Check the strut mounts. Theyll rattle when they go bad. Normally they will allow the car to bounce really bad tho.
    I went NA when a whore left -$300 in my bank account.
  1. Valvetrain Chatter
    By brandonl2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2014, 08:30 PM
  2. Grinding noise from rear when driving in reverse.
    By Alexzander in forum General Tech Discussion
    Last Post: 03-21-2013, 05:04 PM
  3. Rear Suspension Noise Driving me Crazy HELP
    By 94GrandPrixSE in forum Brakes/Suspension/Chassis
    Last Post: 01-22-2013, 10:44 PM
  4. Wiper chatter problem
    By Coldwaves in forum General Grand Prix Discussion
    Last Post: 01-02-2013, 04:33 PM
  5. Squeak in rear end over bumps
    By 2007GrandPrixGT in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2012, 01:29 AM
