Thread: rear o2
Results 1 to 7 of 7
gotboost3 rear o2 04-21-2009, 12:00 PM
Bio248 Re: rear o2 04-21-2009, 12:18 PM
blueguy Re: rear o2 04-21-2009, 12:22 PM
Bio248 Re: rear o2 04-21-2009, 12:32 PM
FoSHO99 Re: rear o2 04-21-2009, 01:17 PM
gotboost3 Re: rear o2 04-21-2009, 01:21 PM
blueguy Re: rear o2 04-21-2009, 02:54 PM
  1. #1 rear o2
    Donating Users
    Plainfield, IL
    if im running no cat should i leave the rear o2 plugged in or unplugged? dont i need to tune for no rear o2? right now i have it plugged and tucked away....when i left it unplugeed i got ****ty mpgs....but i think my front o2 sensor was going bad also at that time lemme know if i can unplug it...
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: rear o2
    you need an o2 simulator or youll always get a bad cat code. the rear o2 has nothing to do with gas mileage, just to tell if the cat is bad or not.
  3. #3 Re: rear o2
    ^^ It does. If it is a '01 or newer.
  4. #4 Re: rear o2
  5. #5 Re: rear o2
    Jan 1970
    Maquoketa, Iowa
    I've been battling it for a while with my 01, finally just did a full write with a 2k .bin and so far so good. The emulator either failed or didn't do its job, but it would still flash like it was working and gas mileage was crap.
    You can also leave the rear 02 plugged in and hang it somewhere, as long as it gets a signal its working it should not throw a code or alter your gas mileage that way.
  6. #6 Re: rear o2
    Donating Users
    Plainfield, IL
    so if i have a 00 can i unplug it with out problem?
  7. #7 Re: rear o2
    Sure...just have someone eventually delete the code permanently IMO.
  1. Rear STB only...
    By a3gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2009, 06:17 PM
  2. rear o2 sensor
    Last Post: 02-22-2009, 08:53 AM
  3. Rear O2
    By probuilder1 in forum General Tech Discussion
    Last Post: 07-27-2008, 10:12 PM
  4. Looking for a used or take of rear bumper
    By Niner in forum Visual/Body Modifications
    Last Post: 05-06-2008, 09:15 AM
