Thread: The Official what you need and how-to for CTS-V brakes
Page 18 of 31 FirstFirst ... 8161718192028 ... LastLast
Results 341 to 360 of 609
  1. #341 Re: The Official what you need and how-to for CTS-V brakes
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    Quote Originally Posted by GrandPrix06GT View Post
    So where do the cts v caliper bolts come from? I've just been looking at prices n comparing to see what it'd run..n gmpartsdirect has 4 for like 30 shipped but then autozone has these ones for 8-9 bucks Duralast/Brake Caliper Bolt/Guide Pin (H15912) | 2006 Cadillac CTS-V 8 Cylinders U 6.0L SFI | AutoZone.com
    ..or am I missing something? Also the banjo bolts I couldn't come across. N last would be the 14 mm bushings..any help would be great. I've been researching for hours today n would just wanna make sure I'd know what to get.
    The ones in the picture are for the standard sliding calipers to the brake caliper bracket. With the Brembo brakes they are a fixed caliper so depending if your doing the front or rears you will use the brake caliper bracket bolts to the knuckle off a Grand Prix in the front and have to come up with custom length bolts for the rear Brembos
    Team JB-Weld
  2. #342 Re: The Official what you need and how-to for CTS-V brakes
    Feb 2013
    Detroit, MI
    Yeah I'd just do the fronts, the backs too much work for me and money probably. Yours are so sick tho. So I'd use my stock bolts n they will hold the Brembo brakes to the knuckle? What is the cts v caliper bolts in the parts needed that drunkie posted?
  3. #343 Re: The Official what you need and how-to for CTS-V brakes
    May 2013
    Dallas TX
    The ones I belive he is talking about are the retaining pin/bolt for the brembo pads but the caliper to knuckle will just be your factory style caliper bracket bolts...hope this helps
    Team JB-Weld
  4. #344 Re: The Official what you need and how-to for CTS-V brakes
    Feb 2013
    Detroit, MI
    Quote Originally Posted by dezebe1 View Post
    Yes thank you, the caliper pin kit he states in quotations next to the calipers..but if you used your caliper bolts stock too then it should work just fine. One more question if you don't mind, Just go to autozone or advanced for the banjo bolts n bushings n say for a cts v?
  5. #345 Re: The Official what you need and how-to for CTS-V brakes
    Jan 2013
    Southern Califorina
    would love to buy a set of those rear caliper brackets. put me on the list for those.
  6. #346 Re: The Official what you need and how-to for CTS-V brakes
    GTP Level Member buickman104's Avatar
    NYC
    Me too
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  7. #347 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Mmmmmm
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  8. #348 Re: The Official what you need and how-to for CTS-V brakes
    Jan 2013
    Southern Califorina
    is there any way of getting some pics posted of the brackets you made?
  9. #349 Re: The Official what you need and how-to for CTS-V brakes
    GTP Level Member
    Sep 2011
    Motown
    Can you post pics of your front setup? I would like to see how much room you have between the wheel and the caliper. Nice setup tho!!
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  10. #350 Re: The Official what you need and how-to for CTS-V brakes
    May 2013
    Dallas TX
    Quote Originally Posted by Classy Pontiac View Post
    Who's setup are you asking about? Lecram25's or my 6 piston fronts??
    Team JB-Weld
  11. #351 Re: The Official what you need and how-to for CTS-V brakes
    GTP Level Member
    Sep 2011
    Motown
    Lecram25
  12. #352 Re: The Official what you need and how-to for CTS-V brakes
    Feb 2013
    Detroit, MI
    Got em on finally, liking them so far. Need to do something with the rears now tho. At least paint em for now n some new rotors.
  13. #353 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    Use the Gxp brake pedal for more leverage as well
  14. #354 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Looking good!! Welcome to the club!... i honestly dont see the need for the gxp pedal, mine is firmmer then stock and i dont have much pedal travel before it starts to stop
  15. #355 Re: The Official what you need and how-to for CTS-V brakes
    NYC
    Agreed, my pedal feels firmer than when the car was stock and i am running front ctsv and rear gxp brakes. looking forward to bracket so can bolt on ctsv rears as well. Either way the brake pedal is fine.
  16. #356 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    Its not about feel guys its about the pedal acting on the linkage sooner giving you better performance
  17. #357 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    Ya i understand that but i dont know if i would want my pedal to act sooner then it already does, then if you barely tap the brakes it would brake harder and faster... which is not necessarily a good thing... my clamping force/ pedal travel reaction is pretty damn good as it is so i personally dont see the need for it... now for the fbody guys ive heard that it is almost a must to get the pedal travel and pressure corrected. Just my 2cents
  18. #358 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    So what happend to Lecram25?? He just disappeared, not able to accept PM's and all his posts are gone it seems....
  19. #359 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2012
    St. Paul
    ... he talked about GPF....
    2007 GXP
  20. #360 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    1st rule of GPF... lol
  1. Official Hello!
    By KawaFord in forum Introductions/Noob Questions
    Last Post: 08-17-2009, 03:56 AM
  2. Ok its official
    Last Post: 08-11-2009, 06:51 AM
  3. Its finally official
    Last Post: 04-03-2009, 09:57 AM
  4. Its Official; Im......
    By Toofastgs in forum The Rant Forum
    Last Post: 02-20-2008, 12:46 AM
