Thread: Another f...in noise!
Results 1 to 5 of 5
  1. #1 Another f...in noise!
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    ok so i have been having alot of noise from my car the past few months i had the control arm bushings both go on me, at seperate times about a month apart.
    the front left strut mount go when tried to replace, found the spring was broken and the strut was finished. so i decided to replace the front and rear suspension all around and drop the car a bit.
    Now i still have a noise dont know what the heck it is. it is a kind of tock tock coming from the front only occasionally when i hit bumps. I have also another noise coming from the front only when the car is cold and i turn the wheel while stationary or moving very slow. sounds like its coming from the strut mounts but they are brand new.
    what else could i check? front suspension is 100% new exept for the sway bar but it wouldnt cause a noise like this.
    I am getting so annoyed with having problem after problem with this car but i love it too much to get rid of it!
  2. #2 Re: Another f...in noise!
    HUDSON
    Check the steering rack mounting bolts, mine were loose on my car making a knock noise on turns, but not all the times. I just put a socket on them and tightend them up, 18mm I think is the size.
  3. #3 Re: Another f...in noise!
    Windsor (ON) Canada
    ^ where exactly would these bolts be.. Im having an odd noise sometimes when turning left (might give this a try)
    ps... It not a bad hub.
  4. #4 Re: Another f...in noise!
    HUDSON
    The steering rack is behind the transmission.
  5. #5 Re: Another f...in noise!
    no the nock isnt when turning, when im turning im hearing a creaking noise like a floor board. the nocking is occasionaly on bumps.
  1. GTP Noise....
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 04-02-2010, 12:01 PM
  2. Odd Noise
    By tdaye in forum General Tech Discussion
    Last Post: 06-19-2009, 07:57 AM
  3. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
  4. Noise help
    By GMPUNK in forum General Tech Discussion
    Last Post: 02-08-2009, 05:07 AM
  5. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
