Thread: GMPP Sway Bar Clearance Issue
Results 1 to 13 of 13
  1. #1 GMPP Sway Bar Clearance Issue
    Port Huron
    Last winter i purchased the GM performance Parts Aftermarket sawy bar for my 2000 Grand Prix GTP. I purchased it from ZZPerformance and they didnt know what to do about my problem.
    Last weekend i jacked up my car to look at some stuff. I noticed when the wheel was turned all the way to the left and right that my inner tie-rod is HITTING MY SWAY BAR. I'm losing about a 1/4 turn of my wheel. There are no after market tie-rods or any thing. Just this sway bar. Does any one have any ideas?
    I was thinking that the spacer that is on the swap bar bushings, if i cut it in half or remove it, this would give me my clearance. BUT can i even do that?
  2. #2 Re: GMPP Sway Bar Clearance Issue
    Jan 2009
    Tallahassee, FL
    You can do that I suppose but if you do also cut the other side to match since the sway bar acts like a torsion spring. Do not cut a lot off though, just enough to get your clearance. I imagine that if you change the mounting a whole lot them your suspension can get thrown off.
    I would try maybe flipping the sway bar first though, It's been a while since I've played with mine but some of the bends car clearance issues with DPs so maybe the same thing is happening with your tie rods.
    I'm sure someone can chime in on this who knows more about suspensions than I do.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: GMPP Sway Bar Clearance Issue
    Willoughby, Ohio
    i was gonna suggest flipping the sway bar too and see if that gives enough clearance
  4. #4 Re: GMPP Sway Bar Clearance Issue
    Port Huron
    Awesome ill try that. I thought it was kind of odd. And i cant remember how i installed it, it was last year. Thanks
  5. #5 Re: GMPP Sway Bar Clearance Issue
    So you guys think flipping the bar will increase the clearance where the endlinks sit?
  6. #6 Re: GMPP Sway Bar Clearance Issue
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Flipping the sway bar had more to do with the sway bar hitting the down pipe more than anything else. You also realize that unless the car was on wheel stands, all your steering and suspension would not be in the same position as it would be when on the ground.
    What I'm saying is you could be seeing a problem that really doesn't exists. I would also think you would of noticed a solid lock when you hit it while driving.
  7. #7 Re: GMPP Sway Bar Clearance Issue
    Port Huron
    I noticed them when the car was jacked up. I did lower it so it is sitting on the ground and they were still hitting, and now that i think about it flipping the swap bar wont lower it. Im going to have to cut those spacers
  8. #8 Re: GMPP Sway Bar Clearance Issue
    Jan 2009
    Tallahassee, FL
    Just be sure to cut them both to the same length.
    77 Morris Garage B
  9. #9 Re: GMPP Sway Bar Clearance Issue
    Port Huron
    Yeah i know. I just dont understand that no one else has come across this. Hell ZZP never heard of this. They told me they didnt know and left it at that
  10. #10 Re: GMPP Sway Bar Clearance Issue
    Willoughby, Ohio
    ^^^i seem to hear that alot
  11. #11 Re: GMPP Sway Bar Clearance Issue
    Port Huron
    hear what? about the sway bar or that ZZP doesnt know anything. lol
  12. #12 Re: GMPP Sway Bar Clearance Issue
    Willoughby, Ohio
    ZZP doesnt know anything!
  13. #13 Re: GMPP Sway Bar Clearance Issue
    Port Huron
    HAHA the more i talk to them i get the same feeling. Or they dont want to help you unless your paying them
  1. gmpp rear sway bar help
    By stanbob123 in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2010, 09:29 PM
  2. GMPP Sway Bar/Suspension Kit
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 06-16-2009, 11:24 AM
  3. GMPP Sway Bar
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2008, 09:07 AM
