Thread: Rear end Clunks
Results 1 to 5 of 5
  1. #1 Rear end Clunks
    SE Level Member reddog's Avatar
    Jul 2010
    Canada
    Hello I just replaced all the struts on my 1998 GTP and now the rear end is making a clunking noise over some bumps but not all the time. It sounds like it's coming from the the righ rear strut. I had the car inspected when I had the struts replaced and the shop said everything is fine. Could it be the sway bar links?
    Thanks
    1998 GTP Stock 2004 GTP Stock
  2. #2 Re: Rear end Clunks
    Willoughby, Ohio
    did you have to strut mounts replaced too? those can make a popping or clunking when worn
  3. #3 Re: Rear end Clunks
    Jul 2010
    Canada
    I don't thinks so. I will check thanks
  4. #4 Re: Rear end Clunks
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    Make sure the trailing arms are tight too.
  5. #5 Re: Rear end Clunks
    Donating Users
    South Deerfield, MA
    I had the exact same problem after doing my whole suspension over. Right rear was clunking over bumps. The strut mount had gone bad after a couple of months.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. Rear end Sag
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 05-18-2010, 07:42 PM
  2. Tranny clunks/no lower gears?
    By SDGTP99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-31-2009, 07:07 PM
  3. rear o2
    Last Post: 04-21-2009, 02:54 PM
  4. Rear STB only...
    By a3gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2009, 06:17 PM
