Thread: Any Help!!!!
Results 1 to 2 of 2
  1. #1 Any Help!!!!
    Cicero
    Hey Guys i have a problem. About 6 months ago i replaced the passenger front strut bearing. Steering was perfect. After we replaced that, i took it for a ride and now i cant turn the car to the drivers side only, but it is not all the time. If i step on the gas it steers easy. The fluid in the resevoir is getting hot also no, i figure i have a blocked passege. But if i lift up the car on either side it doesnt do it. if it was the rack, wouldnt it do it all the time since its "bad". I have both outer tie rods brand new. One thing is that on the drivers side the lower control arm bushing on the front is below the control arm. also i am getting a weird noise like a pressure being trapped or somethin. PLEASE HELP.
    My two front struts when i move the wheel, the area under the hood where the nut is the nut and that rubber are floating, i didnt know if that had anything to do with it.
    I have no leaks or anything. Like i said the steering was perfect bofore i touched that passenger side. About the only thing we did on that side was put a pry bar in the control arm and pry it down to get the hub in the strut.
    2000 Pontiac Grand Prix SE, 3.1 motor.
  2. #2 Re: Any Help!!!!
    are u sure you put the strut back together right when u swapped out the strut mount???sight unseen thats all i can say, and if your mounts are floating around it sounds like u did something wrong, with the installation.
