Thread: Pulsing brakes
Results 1 to 10 of 10
  1. #1 Pulsing brakes
    SE Level Member isptech's Avatar
    effingham, il
    I have noticed on hard Deceleration a slight pulsing in the brakes. Not a big deal, but I probably need to fix it. Here are the details 05 GTP 83K miles. GM replaced the front rotors and pads at 30K miles under warranty. They said the rotors were warped. OEM replacement parts.
    I plan on replacing front and back. Do you think that the problems are the front brakes or back ones? It seems hard for me to believe that the front rotors would warp in just 30K miles again!
  2. #2 Re: Pulsing brakes
    its possible that they could have. Sometimes the rear brakes will be warped and it will feel like it is coming from the front of the car.
    I just saw that my RR rotor has lines in it from being warped. I will be replaceing both rears sometime this summer.
  3. #3 Re: Pulsing brakes
    Donating Users
    South Deerfield, MA
    Generally, you will feel front brake pulsation more in the steering wheel and rear brake pulsation more in the seat. It is definitely possible to need to the brakes after 30K. I have owned several GM's and have never been impressed with the stock pads and rotors.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #4 Re: Pulsing brakes
    if the rotors are ACTUALLY warping then they're **** and never get them again, try rebedding your pads first.
  5. #5 Re: Pulsing brakes
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    You should be able to have the rotors remachined and put new pads on. Most likely your fronts are warped.
  6. #6 Re: Pulsing brakes
    MO
    take off your rotors and have them turned. if you want, you can replace the pads as well. I had the same problem, the rotors measured fine, but i had them turned anyway and it fixed the issue.
    <brandonl2000> LMAO D!!
  7. #7 Re: Pulsing brakes
    Quote Originally Posted by ZR1Vette09 View Post
    This is because you exceeded the heat range of your pads.
    If you just rebedded them again it would have only cost you time and gas.
  8. #8 Re: Pulsing brakes
    MO
    was like that when i bought it. I'm just giving him an option.
  9. #9 Re: Pulsing brakes
    Pennsylvania
    Aside from bad rotos, I've experienced something similar with a little air in my brakelines that needed a good bleed.
  10. #10 Re: Pulsing brakes
    effingham, il
    Thanks for all the input. I will post whenever I figure it out
    Thanks
  1. No brakes...HELP!!
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-17-2009, 01:40 PM
  2. Pulsing in 3rd
    By Dohner in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2009, 08:37 AM
  3. Brakes
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2009, 10:11 PM
  4. Hot Brakes
    By jgold8604 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2008, 04:16 PM
