I have a 02 gp gt and my abs light is on its been on for awhile (at least a couple months) and ive not experienced any problems with my brakes or anything. I dont know if i have a sensor out or what could be it Thanks for the help
Not another one.......long story short.
1) Search the threads
2) get ABS codes scanned (not engine codes)
3) Either bad bearing or bad sensor......
4) Search the threads
Mine was on a year or so ago. I replaced the front hubs and it was still on, w/ the traction control "off" button. I have a 2001 GTP. Anyways, we replaced the abs module under the hood and that fixed it.
Well ya, kinda what I meant when I said light (ABS and TracControl Off) anyways... just checking to see if you had the sound like me.. Im replaceing the hub in a week or two, and Im hoping just that!..and no module![]()
I have the same problem, just had it scanned and got the codes CO550 and C0244. I think its my ebcm. sounds expensive... any thoughts?
Mine actually just started this a coulp days ago...FML.when ever I Decel from higher speeds it sounds like grinding fan. and my ABS light goes off and on. Does this mean its one wheel bearing or both? and how can I find out which one it is....Probably should just take it to the shop but shops tend to say more is wrong and charge more...
On mine a while ago there was corrosion in the abs module connector that caused a pin to break off when i unplugged the connector. I will say that the gtp 4 door abs module is different from the rest, just a warning, get the right one!!
Question Can you change the EBCM yourself or do you have to take it to a dealer???
