Thread: ABS Light On!!!
Results 1 to 18 of 18
  1. #1 ABS Light On!!!
    SE Level Member Cal Cross's Avatar
    Enid, Ok
    I have a 02 gp gt and my abs light is on its been on for awhile (at least a couple months) and ive not experienced any problems with my brakes or anything. I dont know if i have a sensor out or what could be it Thanks for the help
  2. #2 Re: ABS Light On!!!
    Windsor (ON) Canada
    Not another one.......long story short.
    1) Search the threads
    2) get ABS codes scanned (not engine codes)
    3) Either bad bearing or bad sensor......
    4) Search the threads
  3. #3 Re: ABS Light On!!!
    Enid, Ok
    Can I get it scanned at autozone or oriellys
  4. #4 Re: ABS Light On!!!
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    no those scanners wont work on abs youll haft to go to a shop or find sum1 with a scanner/tunner
  5. #5 Re: ABS Light On!!!
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Welcome to the world of ****ty GM HUBS
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  6. #6 Re: ABS Light On!!!
    GTX Level Member Deimos's Avatar
    iowa
    I think sears charge 1 dollar to check it, at least ours does.
  7. #7 Re: ABS Light On!!!
    SE Level Member fatride99's Avatar
    Huber Heights, OH
    Mine was on a year or so ago. I replaced the front hubs and it was still on, w/ the traction control "off" button. I have a 2001 GTP. Anyways, we replaced the abs module under the hood and that fixed it.
    My Ride - '01 GTP Blue/Black (2.dr)
    1949 Mercury Coupe
    R.I.P. - '01 GT Blue/Black
  8. #8 Re: ABS Light On!!!
    liberty
    Question Can you change the EBCM yourself or do you have to take it to a dealer???
  9. #9 Re: ABS Light On!!!
    Windsor (ON) Canada
    fatride...did you have the tell-tale "grinding/propeller" sound when driving?? of just the light on?
  10. #10 Re: ABS Light On!!!
    Huber Heights, OH
    Quote Originally Posted by Colossus View Post
    No, i don't believe so. Both my lights stayed on, never just the ABS light.
    1949 Mercury Coupe
  11. #11 Re: ABS Light On!!!
    Windsor (ON) Canada
    Well ya, kinda what I meant when I said light (ABS and TracControl Off) anyways... just checking to see if you had the sound like me.. Im replaceing the hub in a week or two, and Im hoping just that!..and no module
  12. #12 Re: ABS Light On!!!
    iowa
    if you have a growling sound chances are the wheel bearing sealed bearing has gone bad. Alot of times those puppies come out in two pieces when that happens.
  13. #13 Re: ABS Light On!!!
    Windsor (ON) Canada
    Quote Originally Posted by Deimos View Post
    Did mine this past weekend...here's MY puppy in two pieces.....what a brutal job that was.
  14. #14 Re: ABS Light On!!!
    Overland Park, KS
    I have the same problem, just had it scanned and got the codes CO550 and C0244. I think its my ebcm. sounds expensive... any thoughts?
  15. #15 Re: ABS Light On!!!
    Joliet, IL
    Quote Originally Posted by matt173 View Post
    EM MORAD or the boneyard. im going through the same shyt right now....i got a howling noise on the highway tho....gonna try both front bearings and hope i dont have to do the EBTCM also....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  16. #16 Re: ABS Light On!!!
    SE Level Member SuperCharged0nE's Avatar
    Nov 2009
    KCMO
    Mine actually just started this a coulp days ago...FML. when ever I Decel from higher speeds it sounds like grinding fan. and my ABS light goes off and on. Does this mean its one wheel bearing or both? and how can I find out which one it is....Probably should just take it to the shop but shops tend to say more is wrong and charge more...
    Blown intake weld delete
  17. #17 Re: ABS Light On!!!
    iowa
    Quote Originally Posted by SuperCharged0nE View Post
    Sometimes you have one side making audible noise and the other has freeplay. As a general rule of thumb check them out yourslef they are not that hard.
  18. #18 Re: ABS Light On!!!
    Banned - Busted For Scamming
    Feb 2009
    On mine a while ago there was corrosion in the abs module connector that caused a pin to break off when i unplugged the connector. I will say that the gtp 4 door abs module is different from the rest, just a warning, get the right one!!
  1. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  2. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
