Thread: ABS Light On!!!
Results 1 to 18 of 18
  1. #1 Re: ABS Light On!!!
    Overland Park, KS
    I have the same problem, just had it scanned and got the codes CO550 and C0244. I think its my ebcm. sounds expensive... any thoughts?
  2. #2 Re: ABS Light On!!!
    Joliet, IL
    Quote Originally Posted by matt173 View Post
    EM MORAD or the boneyard. im going through the same shyt right now....i got a howling noise on the highway tho....gonna try both front bearings and hope i dont have to do the EBTCM also....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  3. #3 Re: ABS Light On!!!
    SE Level Member SuperCharged0nE's Avatar
    Nov 2009
    KCMO
    Mine actually just started this a coulp days ago...FML. when ever I Decel from higher speeds it sounds like grinding fan. and my ABS light goes off and on. Does this mean its one wheel bearing or both? and how can I find out which one it is....Probably should just take it to the shop but shops tend to say more is wrong and charge more...
    Blown intake weld delete
  4. #4 Re: ABS Light On!!!
    GTX Level Member Deimos's Avatar
    iowa
    Quote Originally Posted by SuperCharged0nE View Post
    Sometimes you have one side making audible noise and the other has freeplay. As a general rule of thumb check them out yourslef they are not that hard.
  1. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  2. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
