Thread: Any tips or tricks for GMPP sway bar install?
Results 1 to 14 of 14
  1. #1 Re: Any tips or tricks for GMPP sway bar install?
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    We flipped it... I think that it will fit better in the long run anyway.
    So here are my tips for anyone looking to put a front GMPP sway bar on...
    Jack up the car and put it on jack stands.
    Remote the wheels/tires.
    Disconnect the passenger tie rod end from the control arm (just makes it easier later).
    Remove the old sway bar.
    Put the new sway bar in from the passenger side and with the middle "bend" of the bar pointing "down" once it is installed. This give more clearance around the exhaust (especially if you have an upgraded one like I do) and gives better clearances around everything else.
    Put it back together and you are done.
  2. #2 Re: Any tips or tricks for GMPP sway bar install?
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by nickbuol View Post
    couldn't agree more --- it takes a minute and makes the job way easier.
  1. Front Sway Bar Install Issue
    By rileystanek in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:12 PM
  2. GMPP Sway Bars installed
    By dhall9 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 02:04 PM
  3. GMPP Sway Bar/Suspension Kit
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 06-16-2009, 11:24 AM
  4. Last minute tips/tricks/suggestions?
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-15-2009, 10:15 PM
  5. GMPP Sway Bar
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2008, 09:07 AM
